Old 03-24-2014, 03:47 AM   #1
Dodge
Default Kwik way lbm
Hi guys,
I purchased a kwik way line boring machine awhile ago and want to try doing
some insert bearing installations.
Every thing is pretty straight forward and the machine is complete and I have
a good set of instructions.
My question is what is every one using to cut the thrust surface for the bronze
insert thrust washers.
I have seen one post on using a rotary table to cut the rear main cap, but
wouldn't it be better to machine it on the block?
And what are people using to cut the front side of the rear main block surface
as it is an interrupted cut.
I can't find any posts on this.
Thanks,
Dodge
Dodge is offline   Reply With Quote
