#1 |
I would like to convert my 35' coupe to juice brakes and wondered if anyone made a set of pre bent brake lines? Any information would be appreciated.
Thanks Dan |
#2 |
Dan. Have you thought of installing energizers? They're about $56 and work just as well as hydraulics.
#3 |
WILL and WILLIT..... Are you guys related????
#4 |
Try Richard at the Early V-8 garage,
(626) 338-2282. He furnished everything we needed for our 34 and 36 5 window coupes. Fit like they came from factory!! |
#5 |
#6 |
#7 |
I plan on buying Richards master cylinder mouting bracket but I thought his price for brake lines was bit high at 395.00. I can make my own but thought if I could buy a pre bent set reasonable I would go that route and be done with it.
#8 |
C&G Early Ford Parts sells the energizers(floaters).Part#48-2043. $54.95.
Their phone number is 1-800-266-0470. I put them on my '36 and I'm very pleased.It might be worth looking into Dad. |
#9 |
My 35 coupe has juice brakes. You can buy the brake lines for a 39' and they will be much cheaper. Check Spadero or Early Ford V8 in SC.
The early V8 garage master cylinder mount is pretty simple to fabricate. I used his pics as a reference and saved a bunch of money on my 34 pickup. My 35 coupe has a 39 pedal assembly. You will still need to mount the conectors and go thru the inner fender panels for the hoses etc. |
#10 | |
![]() Quote:
Did you do the master with the bell crank that mounts sideways to the frame? |
#11 |
Read number four site how do I know
#12 |
#13 |
Brake lines are a walk in the park to bend up out of the softer cupro nickel tube . It still complies with all regulations and bend and flares real nice.
#14 |
I put brake floaters on my '35 fordor sedan last spring and they made a huge difference in how this car brakes. I have driven cars with hydraulic brake conversions, using '39-'48 components, that did not stop as well as my car stops now. The new Lincoln brake offers may be a different story.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-22-2014 at 09:35 AM. |
#15 |
The 35 never had juice brakes as standard. Any 35 converted to juice brakes is non standard. How would you expect a supplier to tool up to supply pre bent brake pipes for a non standard application? Unless the supplier were doing the conversions themselves no two would be alike.
If you move away from stock you have to be prepared to do some things yourself. Mart. |
#16 |
I have floaters on my 36 pickup with soft lining, it stops very well. the 36 feels like it has power brakes compared to my model a witch has 48 juice brakes!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#17 |
What kind of brake floaters do you have? Just curious.
#18 |
I agree with my4dv8 on the cupro nickel brake line. Got mine at CARQUEST. beautiful bends with a bender or just use your fingers. Double flares are no problem with a basic double flaring tool.
#19 | |
![]() Quote:
"Never complain,never explain"... Henry Ford II Last edited by 37 Coupe; 03-22-2014 at 08:45 AM. |
#20 |
The set I used was purchased from MAC's Antigue Auto Parts maybe 10 years ago. This was before I was aware of Flathead Ted's floaters. I plan to use a set of his floaters for my '35 coupe. I believe MAC's still offers both Ted's and a lower cost brand in their catalog, or at least they did the last time I checked.
