Old 03-15-2014, 09:24 AM   #1
Billludwig
Billludwig's Avatar
Default How to remove spark & throttle levers?
I can't seem to figure out how to remove the spark advance and throttle levers. I don't see anything removable down at the spring end of the rods. Help!
Billludwig is offline   Reply With Quote
Old 03-15-2014, 09:51 AM   #2
Bill in NJ
Default Re: How to remove spark & throttle levers?
On the lower end is an arm to hook the gas and spark rods to. There is a little pin that goes thru those arms. The pins have to come out. Hope I explained it properly.
Bill in NJ is offline   Reply With Quote
Old 03-15-2014, 09:58 AM   #3
Mitch//pa
Those pins that bill talked about are a PIA. I have found it tough to get them out without doing damage to the column paint, rods and levers.
Since i was replacing mine i whizzed off the rods above the levers at the bottom of collumn and went together with new rods, springs and levers.
Old 03-15-2014, 10:00 AM   #4
Cape Codder
Cape Codder's Avatar
Bill in NJ is correct and then a lot of tapping on the arm and pulling to get the lever rods out or at least mine were very tight coming out. Hope this also helps.
Cape Codder is offline   Reply With Quote
Old 03-15-2014, 10:07 AM   #5
Billludwig
Billludwig's Avatar
Thanks for the help, guys! Understood.
Old 03-15-2014, 10:17 AM   #6
1crosscut
1crosscut's Avatar
If you take a nut driver or socket that is small enough to fit up against the bottom of the arm and still leave room for the rod to pass through you can strike the nut driver/socket with a hammer and push the arm up shearing the pins.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-15-2014, 11:54 AM   #7
700rpm
700rpm's Avatar
1crosscut has the right solution. Those pins are very soft and will shear off when hammered as he describes. Then the control arms and springs will easily slide off, and you can pull the rods up through the upper column bushing, if the whole outfit isn't too rusty.
Ray Horton, Portland, OR
Old 03-15-2014, 08:22 PM   #8
QGolden
QGolden's Avatar
+1 and that is the process that Les describes for removal in the book.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
