Old 02-20-2014, 07:21 PM   #1
Rex Smith
Rex Smith's Avatar
Default Removing Door Handle
I'm trying to remove the door handle off my '30 pickup. It's the locking outside handle. Everything else is off, including all the screws and the inside handle. The latch mech on the edge of the door is unscrewed. The book says to turn the handle 1/4 turn to the left and pull out. Nothing works. Any suggestions?
Rex Smith is offline   Reply With Quote
Old 02-20-2014, 08:08 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Removing Door Handle
Ditto. Only remove the two screws holding the handle on. The rest of the latch needs to be tight or it could cause the handle to bind as you attempt to turn and remove. Don't pry on it with anything. Turn and pull.
Mike Peters is offline   Reply With Quote
Old 02-20-2014, 08:55 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Pushing the flap in will relieve a bit of pressure, and I also try to spray some penetrating oil on the shaft, then wiggle it as I pull. As Vince said, it's 1/8 turn, not 1/4 turn.
Old 02-21-2014, 10:37 AM   #4
Rex Smith
Rex Smith's Avatar
Thanks for the info. I'll let you know how it goes. "The Book" is Les Andrews Model A Ford Mechanics Handbook (the red one) page 1-108
Old 02-21-2014, 11:38 AM   #5
Tom Wesenberg
I think most of the guys know it's 1/8 turn, but just mistakenly call it 1/4 turn.
Old 02-21-2014, 07:36 PM   #6
Rex Smith
Rex Smith's Avatar
Unfortunately, it's still no go. I've screwed the locking mech back on and doused it with Croil. There's no hint of that thing moving out. I've put the door on the floor, stood on the edge of it and pulled with all my might in numerous positions. All I've managed so far is a sore back.
Old 02-21-2014, 11:41 PM   #7
Tom Wesenberg
Here's a link to 4 pictures I posted earlier, that might help.
https://www.fordbarn.com/forum/showth...or+latch+tudor
Old 02-21-2014, 11:54 PM   #8
28ACoupe
28ACoupe's Avatar
Rex - we will get it out on Sunday. See you then.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 02-22-2014, 10:46 AM   #9
Rex Smith
Rex Smith's Avatar
Looking forward to it 28ACoupe. I've tried all positions... 1/8 turn, 1/4 turn, 1/2 turn, full turn, no turn, all turns in between. Looking forward to posting what the problem was; probably user error.
Old 02-22-2014, 11:35 AM   #10
Steve Plucker
Are you turning it the Right way or the Left way?
Sometimes that area gets rusted and may be the case without looking at it.
Good luck.
Pluck
Old 02-23-2014, 11:59 PM   #11
28ACoupe
28ACoupe's Avatar
We managed to get the door handles out of the truck today. It took a good deal more work than it should have due to the preponderance of rust. Basically, the knob-rod was rust-welded into the actuator piece and needed some convincing to get it out.
Old 02-24-2014, 10:59 AM   #12
Rex Smith
Rex Smith's Avatar
It was rusted stuck tight; had to be driven out. Hard blows with a punch.
Old 02-24-2014, 12:43 PM   #13
Brentwood Bob
Good to learn you got them out finally with BFH. Bob
Brentwood Bob is offline   Reply With Quote
