Old 02-18-2014, 09:57 PM   #1
Fredb_
Fredb_'s Avatar
Default Is this uncommon?
I pulled the heads from the 59 Block that I showed on YouTube yesterday. It has STD pistons and very little ridge at top of cylinder. Is it uncommon to find one that has not been bored out? If interested I'm selling this one to help finance two other motor projects.
Fredb_ is offline   Reply With Quote
Old 02-18-2014, 09:59 PM   #2
4tford
4tford's Avatar
Default Re: Is this uncommon?
I run into them once in a while, Had an 8ba a couple of months ago. Polished the crank and used .002 bearings on both mains and rods.
4tford is offline   Reply With Quote
Old 02-18-2014, 10:03 PM   #3
alan
I would have checked vacuum and done a hot compression check and then left it alone if the numbers were ok,
alan is offline   Reply With Quote
Old 02-18-2014, 10:05 PM   #4
Royal Ryser
Mine is like that, too. Also, the valve galley was clean, almost no buildup.
Royal Ryser is offline   Reply With Quote
Old 02-18-2014, 10:28 PM   #5
flatjack9
flatjack9's Avatar
What size is the bore? I've seen 3 5/16 pistons with a std mark on them.
Old 02-18-2014, 10:32 PM   #6
Fredb_
Fredb_'s Avatar
Good point flatjack9. I wouldn't a thunk o' that!
Old 02-18-2014, 10:37 PM   #7
Mike in AZ
Mike in AZ's Avatar
any letter along with the 59 on the bellhousing??....factory relief, looks like....Mike
Mike in AZ is offline   Reply With Quote
Old 02-18-2014, 10:39 PM   #8
Charlie Stephens
Any chance it has been sleeved?
Charlie Stephens
Old 02-18-2014, 11:22 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
The first picture sure looks like that cylinder is sleeved to me when I blow that picture up. I think I am seeing a sleeve down in the relieved area as well as the non relieved area around the bore. Not as obvious on the other cylinders pictured. Some of these 59 engines were sleeved to a 3-1/16" bore and used as service replacements for earlier engines.
John
Old 02-18-2014, 11:29 PM   #10
mrtexas
mrtexas's Avatar
The bore on my 37 engine is standard and the rods are standard as well. Has some wear on the cylinders however.
mrtexas is offline   Reply With Quote
Old 02-19-2014, 08:29 PM   #11
Fredb_
Fredb_'s Avatar
Default Re: Is this uncommon? **Update**
I pulled the intake manifold and uploaded some photos and a video to this location if you're interested in looking at more of this 59 Block.
http://1drv.ms/1htJRhW
Old 02-20-2014, 01:24 AM   #12
40 Deluxe
Another thing to watch for: A ring job done on worn cylinders. It could have had a bad ridge before a ridge reamer was used. So now the bore looks good but best to mike it to be sure
Old 02-20-2014, 09:38 AM   #13
Uptown83
Uptown83's Avatar
I bought a running 8ba for my 35. It is standard bore and virtually no ridge. I just thought I lucked out
Uptown83 is offline   Reply With Quote
