Old 02-13-2014, 05:15 PM   #1
josh1331
Default 6 volt alternator.
Anyone know if there is a complete kit to purchase for changing over to 6 volt alternator and removing generator? And who might vendor be. Thanks
josh1331 is offline   Reply With Quote
Old 02-13-2014, 05:53 PM   #2
mrtexas
mrtexas's Avatar
Default Re: 6 volt alternator.
Probably not. On my 37 engine I had to replace the intake manifold with a later model to use a GM cheap alternator. There are those out there replacing the guts of your generator with an alternator although be prepared to pay $600+ for that service.
mrtexas is offline   Reply With Quote
Old 02-13-2014, 06:25 PM   #3
4dFord/SC
4dFord/SC's Avatar
Ed Whitney can convert your 6v Ford generator to an alternator: (714) 773-1611.
4dFord/SC is offline   Reply With Quote
Old 02-13-2014, 06:29 PM   #4
tubman
tubman's Avatar
Check with Summit. They have "Powermaster" 6V alternators listed. A little expensive, however.
Old 02-14-2014, 10:25 AM   #5
len
Fith Ave in kansas has a 6 volt setup.
len is offline   Reply With Quote
Old 02-14-2014, 11:18 AM   #6
51504bat
51504bat's Avatar
Try these guys. They list 6 volt alternators and brackets as well as the more pricey Powergen units. I got the 12 volt single wire alternator and bracket for the 8ba in my 40 from them. Good price and it works like a dream.
Quality Power
www.qualitypowerauto.com
31510 Yucaipa Blvd, Yucaipa, CA 92399
(909) 794-1600
Old 02-14-2014, 01:16 PM   #7
jr9162
http://www.fifthaveinternetgarage.co...%20Gazette.pdf
jr9162 is offline   Reply With Quote
Old 02-14-2014, 02:42 PM   #8
48fordconv
I had a 6 volt alternator made from a aguy in Some magagzine. He used the front of a 48 FORD Gen and adapted a 12 volt alternator 1 wire and convered to 6 volt. Works super and you use same bracket and fan belt.
48fordconv is offline   Reply With Quote
Old 02-14-2014, 05:51 PM   #9
cmbrucew
cmbrucew's Avatar
I have bought parts from these people.
Build your own and save money.
Bruce
Works good
Lasts long time
http://alternatorparts.com/10si-all-in-one.html
cmbrucew is offline   Reply With Quote
Old 02-14-2014, 08:24 PM   #10
42guy
42guy's Avatar
Certified Auto Electric ph 1-888-597-8278 www.certifiedautoelectric.com. Got mine from them for my42.
42guy is offline   Reply With Quote
Old 02-14-2014, 08:36 PM   #11
Ross F-1
Ross F-1's Avatar
No matter where you get the alternator, you'll have to make some wiring changes on your own.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 02-14-2014, 09:56 PM   #12
Drbrown
Drbrown's Avatar
Be sure the ALT unit or kit has an internal voltage regulator. Remove and by-pass your original Voltage Regulator box. Don't short-change your system - use 8 guage wire for supply. One-wire type/arrangement may be easier to hook up but three-wire type better for sensing system voltage use/drop. Use a voltage guage instead of amp guage. Dan
Drbrown is offline   Reply With Quote
Old 02-14-2014, 11:46 PM   #13
41ford1
41ford1's Avatar
Check with HD on here. He does 6v alternator conversions out of Willmington, MA.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 02-14-2014, 11:59 PM   #14
al's28/33
al's28/33's Avatar
Certified Auto Electric and EJ Whitney are the two worth researching.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-15-2014, 08:15 AM   #15
don-wi
Is it possible to make an alternator positive ground?
don-wi is offline   Reply With Quote
Old 02-15-2014, 08:43 AM   #16
BILL WZOREK
BILL WZOREK's Avatar
Yes , I have not done it YET!!! but I know that it is done. What it takes to do it. & I hope someone will Chime in how to acomplish it.
BILL WZOREK is offline   Reply With Quote
Old 02-15-2014, 09:01 AM   #17
G.M.
YES you have to reverse the polarity of the diodes by the way they are mounted. Easier to buy reverse polarity diodes or replace the entire bridge rectifier which is the complete diode assembly. it's easy to convert a GM 12 to 6 volt POS ground, it takes all stock parts. If making a 6 volt alternator from a GM alternator you should also use a 24 volt stator so it charges at idle speeds with a stock old Ford pulley. I made 7 alternators for my own use using Nippendso small 12 volt alternators inside the 39 Ford generator shells. I mounted the rectifiers and adjustable voltage regulator on the inside of the rear brush holder cap as a plug in assembly. I made 2 extra cap assemblies for spares if I ever had a problem but never needed them after 10,000 miles. I even made an alternator/generator test machine to run load tests on them. I can't locate the pictures right now but will take some more and open a new topic later. G.M.
www.fordcollector.com
