Old 01-12-2014, 10:24 AM   #1
fiddlybits
fiddlybits's Avatar
Default Tire question
I have been helping a friend with his Model A and yesterday we were fixing the flat tires.
We were pleased to find that the wheels are clean of rust, both surface and inside the rim and that they run true. We decided to clean them and paint them shiny black and they are all set for the tires to go back on.
The question we have is: There are no "rubber bands" on any of the rims. Since the rims are clean and smooth are these needed?
Thanks
Scot
fiddlybits is offline   Reply With Quote
Old 01-12-2014, 10:40 AM   #2
Steve Plucker
Default Re: Tire question
Pros and cons...but I have always put them on just as a safegaurd.
Pluck
Old 01-12-2014, 10:50 AM   #3
rons49
rons49's Avatar
Me too. I bought "flaps" from Coker when I purchased my Firestones a few years ago. I did powder coat the wheels, however. I feel that Pcoating is more durable and is more resistant to chips when installing the tire/tub with the spoons.
rons49 is offline   Reply With Quote
Old 01-12-2014, 10:53 AM   #4
Mitch//pa
i always use them and for 2.50 each why not. i bought the good quality brattons metal stem tubes for 34.00 each the bands add piece of mind.
Old 01-12-2014, 10:54 AM   #5
fiddlybits
fiddlybits's Avatar
ok, great.
I am curious what the pros and cons are.
I "assume" that the purpose is to protect the tubes from the spokes....but beings that that wheel is a welded spoke design, and the spokes do not protrude inside of the wheel, we were very surprised to find them in two of the five tires, as they would seem un-needed and it seems that they would just be one more item to affect the balance.
We're going to mount all without for now but put it on our revisit list.
Old 01-12-2014, 04:30 PM   #6
Hicktick
Hicktick's Avatar
Ford used them for a reason , flats are no fun to me .
One grain of sand can work its way into the tube and you are flat .
Tubes will rub inside , all it takes is low air pressure from sitting .
Hicktick is offline   Reply With Quote
Old 01-12-2014, 06:14 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Thanks
Scot
No the are not needed but, I have not yet met someone that did not have something like a liner, flap, or duct tape.
Old 01-12-2014, 07:02 PM   #8
1931 flamingo
1931 flamingo's Avatar
Cheap insurance for what they cost. FWIW
Paul in CT
Old 01-13-2014, 12:10 AM   #9
fiddlybits
fiddlybits's Avatar
Guys, I getting confused here.
What I am reading is they are not needed but....
"They are cheap insurance...."
"They give peace of mind....."
"They are a safeguard... "
......but against what?
My question now is: Did Ford ever install these or were they added later when a rim had a problem?
Some thoughts:
On my old motorcycles I had spoked wheels and the purpose of the rubber band was to protect the inner-tube from the ends of the spokes. But the Model A wheels use a welded spoke that does not go through the rim.
If it is to keep the tube from contacting metal then the rubber band is too narrow as it only covers the valley bottom. The tube would still contact the metal from the bead to the valley walls.
The rim is not a split rim so there is no need for protection from the split.
I could see installing them if I had rust or rough surface problem on the inside of the rims but a new wheel would not have this. (and we don't)
An old story:
My wife was preparing a ham one time and I watched as she cut the end off the ham and put it in the pan. I asked her why she cut off about 1/5 of the ham and she said that it was the way her mother taught her to bake a ham. Curious, I call my Mother In Law and asked her why she had taught my wife to prepare the ham that way. She said that it was the way HER mother had taught her. When asked about this her mother said "the whole ham would not fit in the tiny pan she had".
So, for 2 generations a procedure had been performed for no reason at all other than "that's the way I was taught". It was never questioned.
Are rim liners (rubber bands) being put in because "we always have"?
Respectfully, what is the purpose of the rim liner in our Model A wheels?
Scot
Old 01-13-2014, 12:39 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
"Respectfully, what is the purpose of the rim liner in our Model A wheels?"
They protect you from the fear of what could happen if you didn't have them.
Actually the original wheels had thick paper liners, and I have an original liner still on one of my wheels. Sometimes the electrically welded spokes left a little spike of sharp steel that could poke a hole in the tube. If your rims have no rough spots from rust and no weld spikes, then you probably have no need for the liners.
Old 01-13-2014, 12:52 AM   #11
Mike V. Florida
Rough insides of the wheels
See Tom's post above
Some thoughts:
But in some cases roughens up the surface, See Toms post.
There are liners and there are flaps, flaps are wider. Depends on how bad the metal is
Then don't install them, no post here has said you HAVE to.
An old story:
NO, most are not as lucky as you to have wheels in such great shape. Restorers put them in due to not wanting to take a chance on missing something on the wheel and they are cheap insurance. You can use duct tape if you want.
Re-read the thread to see several reasons.
Scot
You asked a question and were given answers, put them in don't put them it the decision is yours. My wheels were rough in the deepest part of the wheel. It was easier to put in a liner then to restore the metal to smooth.
Old 01-13-2014, 02:21 AM   #12
fiddlybits
fiddlybits's Avatar
I am sorry, I don't know what just happened.
I am new at this and obviously I have done something that was offending but I don't know what I did.
I was just trying to find out if these were a needed item and why they were or why they are being install if they are not.
I guess I'll just google it from now on.
Thanks for your time.
Scot
Old 01-13-2014, 03:28 AM   #13
Mike V. Florida
Scot
The problem was, you received your answer but kept asking the question. You did it again here. You asked if they were a needed item and got the answer, depends on the condition of the wheel.
You asked why were they being installed if not needed and you got the answer, insurance in case something was missed.
I sorry if you did not like the answer you read.
You are of course welcome to ask more questions if you like, but you were beating a dead horse on this one.
You really want to be confused, ask what oil is best for A model A.
Old 01-13-2014, 06:27 AM   #14
RonC
RonC's Avatar
I use the liners and coat everything with a generous amount of baby powder.
RonC is offline   Reply With Quote
Old 01-13-2014, 06:50 AM   #15
Franchise_24
Franchise_24's Avatar
Here is the way I look at it. It's great that you have good rims, and as cheap as the liners are, why not just put them in? I am getting ready to pull all 4 of my tires. I'm going to sandblast the rims and repaint them, Mine will be nice too, but I am still going to put liners on, then new tubes and "newerish" tires if that makes sense lol. No need to get upset and google things from now on, ask away and we will all answer as best we can.
Bottom line, you have the tires off, put rim liners on, it can only help.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 01-13-2014, 07:06 AM   #16
ronn
duck tape gets rid of the quack!
at the very least..........
Old 01-13-2014, 07:51 AM   #17
jerry shook
Scott. Ask the same questions as many times as you need to. This a form were some will help you if they can. You are new here you will learn.
jerry shook is offline   Reply With Quote
Old 01-13-2014, 08:31 AM   #18
RonC
RonC's Avatar
I've pulled apart many wheels-tires that had no rim liners at all and the tubes were decades old and still held air. Personally I use liners as I feel it adds a little extra protection against scuffing on the tubes. Your rims could be pefect now but get some water in there and rust will start to form creating an abrasive surface. In addition tubes available today do not seem to be anywhere near the quality rubber of older tubes.
Old 01-13-2014, 09:53 AM   #19
fiddlybits
fiddlybits's Avatar
I liked the answer I read....the very first answer. Post #2.
My post #5 was in response to post #2, that originally stated, as the first line, that they were not needed. (The first line of that reply is not there now.) That is why my reply started with "OK, great" and ended with we were going to mount without and revisit this later.
Reply #3 & #4 came in while I was typing #5.
I had my answer of they were not needed and you stated that in your post #7. (But there was no reason why they were being used.)
And then the other answers started appearing. So I asked what the purpose was. (different question)
I fail to see where I was beating a dead horse.
Tom Wesenberg answered that question with the info on the paper liner and the pointy welds. No other answer prior to that had a reason. I asked no more questions after I got the answers.
FWIW, To all those that helped, my friends grandfather was very please that we not only mounted his tires but took the time to find out the information.
Scot
Old 01-13-2014, 09:59 AM   #20
Franchise_24
Scot
Glad to have you here Scot. If you stick around you will learn that you just need to ignore some people that's all....
