#1 |
Can not find any photos or drawings as where wood goes and bolts used in body to frame and bed to frame..one would think Model A sites would better at showing how to restore a rig..I bot a book how to restore Model A pickup ..total junk and no help at all .. ..SC
#2 |
Here are a few pictures from my restoration
1929 Model A speedster 1930 Model A Coupe 1930 Model A Fordor 1931 Model A Pickup 1931 Model A Victoria 1931 Model A Fordor 1914 model T Touring 1915 Buick C-25 Touring |
#3 |
bottom corner 30-31
www.whidbeymodelaclub.com |
#4 |
I went through my pictures and don't have any detailed shots showing the cab to frame and the bed to frame wood and bolts.
Can't recall the specifics of it but it was fairly straight forward. The bed was the easiest. Think it is held in place by four bolts; two on each side. Bratton's has a good diagram of the placement and orientation of the body blocks in their catalog. If you don't have a copy, call them up and they'll send you one. The Kit is $31. -Tim |
#5 |
This is the inside wood,
#6 |
#7 |
"The Model A Ford as Henry Built it" has that info in it. Great book !!!!
#8 |
Great info so far.. ..thanks much,,I'm sure others will and can use this info also as there is not much out there about wood placement and bolts..sc
#9 | |
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole.
#10 |
I just finished a roadster PU. Not sure if the closed PU is the same. THere are 3 pieces of wood per side, under the body. One block has the two holes that goes toward the front, behind the firewall bolt hole (no wood under that, just washers). If I remember correctly this block slides in place. The second one goes perpendicular to the frame, inside the subframe channel. The third one back is a short, narrow block that I think went perpendicular to the frame as well.
Like I said this is an open pick up and may be very different than a closed. Good luck. |
