Old 10-07-2013, 07:45 AM   #1
sphooch
sphooch's Avatar
Default 31 roadster gas tank
I plan on installing my gas tank soon , the plan is to have it boiled out by a radiator shop then use the gas tank restorer which Kanter sells to seal the tank. yes the tank is out of the car. has anyone used this product before?? if so do you have any helpful hints to pass along?? thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 10-07-2013, 09:08 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 31 roadster gas tank
Not sure THAT is the product you want to use. The MSDS lists it as Permatex Gasket Sealer. There has been countless failures with it using fuel available here in the States.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-07-2013, 09:45 AM   #3
flatford39
If you can find someone to boil it out and it is clean I don't know the purpose of the sealant. If it doesn't leak I would leave it like Henry let it leave the assembly line.
flatford39 is offline   Reply With Quote
Old 10-07-2013, 12:59 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I thought the tanks were tern coated inside?
Old 10-07-2013, 02:32 PM   #5
BRENT in 10-uh-C
Here is yet another misconception. The Terne finish that was the protective coating was a non-durable coating that deteriorates over the years. THAT in a nutshell is why many tanks have rust inside. Over time and after the Terne coating has rubbed off and it exposes the bare metal underneath. Fuel has oxygenizers in it, plus areas exposed to oxygen will flash rush in the matter of hours. As the fuel splashes by when the vehicle is driven, it dislodges the rust particles and puts them in suspension of the fuel. When the rust is removed from the bare metal, the rusting process cycles all over again. Unless the oxygen is sealed from the metal, it will continue to rust creating more debris in the gas tank.
BRENT in 10-uh-C
Old 10-07-2013, 03:14 PM   #6
Skrain
Skrain's Avatar
Interesting thought...while working on getting the rust out of the tank on the 29, I looked inside the tank of my 49 8-N tractor parked next to it.
The inside of the tank was SHINY! It sits a lot more then the 29. I wonder what is inside the 8-N tank to keep it from rusting like the "A" tank does?
"They can make me grow older, but they CAN'T make me grow up!"
Skrain is offline   Reply With Quote
Old 10-07-2013, 04:21 PM   #7
Mike V. Florida
Good to know.
Old 10-07-2013, 08:03 PM   #8
Raven
Sphooch...did you have any trouble removing the fuel tank from your '31 Roadster?
Raven is offline   Reply With Quote
Old 10-07-2013, 09:40 PM   #9
Garychinook
No experience yet with Model As. A lot of experience w/ motorcycle tanks. I use the POR 15 cleaner and metal etch with w/ a wod of sheet rock screws. I DO NOT USE THE POR15 final slushing compound. I use and am very very satisfied with the Caswell product final tank interior product. Good stuff.
My 2 cents, Gary
Garychinook is offline   Reply With Quote
Old 10-08-2013, 11:18 AM   #10
ford3
use 2 oz of mavel mystery oil to every gallon of gas you put in tank, its not only good for the intake valves and upper cylinders it will also leave a real thin coating of mmo on the inside of fuel tank to help prevent rust formation
ford3 is offline   Reply With Quote
Old 10-08-2013, 03:10 PM   #11
sphooch
sphooch's Avatar
No trouble at all but , I had only a bare bones car to start with, I just un bolted it and out it came . have fun THE HOOCH
