Old 08-20-2010, 10:44 AM   #1
oldskool
oldskool's Avatar
Default 8BA in 41 ford fan fix
i know there are several ways around mounting a fan on an 8ba in a 41 ford ,i choose to retain the original 41 fan and had a machine shop make an adaptor plate and mated it to the 8ba pulley,i still have over 1" clearence between fan and rad .hope this helps someone else,p/s this may work on a 40 ford also..al
oldskool is offline   Reply With Quote
Old 08-20-2010, 10:51 AM   #2
19Fordy
19Fordy's Avatar
Default Re: 8BA in 41 ford fan fix
How thick was the adapter plate?
Did you have any balancing issues?
Are those fan blades bent or are my eyes fooling me?
Thanks.
Old 08-20-2010, 11:42 AM   #3
oldskool
oldskool's Avatar
Thanks.
the plate is 5/16 thick,tapped for 5/16 fine tread as original,the blades are straight and has no balance or vibration issues...the plate fits into a recess in the pully and the fan hub has a small lip that centers itself to the adaptor plate so its prefectly centered...al
Old 08-20-2010, 12:00 PM   #4
flatjack9
flatjack9's Avatar
On my 39 with an 8BA, I simply used the 39 pulley and bolted the fan directly to it.
Old 08-20-2010, 01:04 PM   #5
oldskool
oldskool's Avatar
i was informed there would be a belt misalignment useing the 39/41 crank pulley with my application and would also have to remove a spacer or seal bushing,just what i was told.al
Old 08-20-2010, 01:20 PM   #6
19Fordy
19Fordy's Avatar
Thank you.
Old 08-20-2010, 06:31 PM   #7
flatjack9
flatjack9's Avatar
I kept the 8BA sleeve and trimmed the back of the pulley to align the belt. The sleeve could be removed, however that is not easy to do after the engine is assembled.
Old 08-21-2010, 12:04 PM   #8
alan
did the same for the 8CM in my 41 truck, but had to reposition the belt pully to get the correct alignment for one belt drive
alan is offline   Reply With Quote
Old 08-21-2010, 01:42 PM   #9
40fordpu
40fordpu's Avatar
Can you show us some pics of the belt alignment in the car? Do you have pics of all the pieces as well...thanks
40fordpu is offline   Reply With Quote
Old 08-21-2010, 02:41 PM   #10
oldskool
oldskool's Avatar
the pulley is stock 8ba out of a 50 pu,so there was never any belt alignment issues, i had the shop make me a round plate made out of 5/16 flat stock tthat fits into the pulley recess,was drilled and tapped to match the fan hub,the hole deal cost me 50 bucks...al
Old 08-21-2010, 06:06 PM   #11
donald1950
nice job. i though of doing something like that when i did the 8BA in my 41 truck but went the route of a modified 8BA 1949 car fan. yours is much nicer. don
donald1950 is offline   Reply With Quote
Old 08-22-2010, 01:13 PM   #12
40fordpu
40fordpu's Avatar
So the original 40 fan was a 4 blade for a car and truck? The pulley looks trick by the way
Old 08-22-2010, 01:30 PM   #13
oldskool
oldskool's Avatar
the fan has six blades not 4 , just looks like 4 in pic,this sucker really draws air even at idle... i think both cars and trucks had 6 blade fans in 40-41
