Old 08-16-2010, 08:18 AM   #1
Mitch//pa
Default filter in sediment bulb
looking for some feed back on putting the paper fuel filter in the glass sediment bulb with a spring underneath. i dont have any trouble now just not looking to create trouble.
thanks
Old 08-16-2010, 09:05 AM   #2
steve s
steve s's Avatar
Default Re: filter in sediment bulb
Those things are probably the most seductive modification out there. Here's a picture of most of the filters I have tried over the years. Everyone but the pink fiberglass one was trouble, and it's no longer available; it's same-model-number replacement is paper and of very shoddy construction.
My understanding is that most filters are designed to work with a fuel pump. I have seen a lot of other folks have their problems solved by REMOVING a fuel filter, while many others on this board report no problems. The clear plastic inline filter filled up with vapor as I watched and shut down the motor--never really made it out of the driveway. That slick little micro filter held up with the spring is the most seductive and troublesome--you may get a few miles on it. My guess is that filters work ok for folks whose system is so clean that they don't need them. Also, I believe that some of their problems are related to the nefarious vapor pressure issue, as they provide a potential locus for bubble formation and blockage.
My advice: Don't do it! (Results may vary.)
Steve
steve s is offline   Reply With Quote
Old 08-16-2010, 09:10 AM   #3
V4F
V4F's Avatar
i use a wix filter in my bowl with no problems . ............... steve
V4f
V4F is offline   Reply With Quote
Old 08-16-2010, 09:15 AM   #4
Mitch//pa
i was thinking of going with the gf18 pictured above in steve s post with a spring under it
Old 08-16-2010, 09:19 AM   #5
Tacoma Bob
Tacoma Bob's Avatar
I have run the wix filter with no problems what so ever. In fact just put a new one in yesterday. There was just a bit of very fine crud in the bottom of the glass. That plastic with the spring did the same for me. Got about 5 miles and it collapsed.
Tacoma Bob is offline   Reply With Quote
Old 08-16-2010, 01:10 PM   #6
Bill Steiner
I just use the screen in mine. Bill
Bill Steiner is offline   Reply With Quote
Old 08-16-2010, 02:35 PM   #7
Farrell In Vancouver
Farrell In Vancouver's Avatar
Any one ever try an aftermarket Harley fuel line filter?
Designed for a gravity feed system they would probably work fine.
Farrell In Vancouver is offline   Reply With Quote
Old 08-16-2010, 05:23 PM   #8
california dean
My 30 A had a paper filter in the sediment bowl and a metal inline filter when I got it. The glass bowl always looked great but I had vapor lock/poor fuel flow problems especially when it was hot weather. Took the metal inline filter out and things improved but were still not right. Finally took the paper filter out to check it and found it totally full of swamp debris INSIDE the filter. Checking the sediment bowl out I found that the fuel comes from the tank to the inside of the paper filter, then clean fuel in the visible part of the bowl goes up and out to the carb. Moral of the story is that it's worth your time to check how the sediment bowl works if you're going to use a filter. If you elect to not use a filter it doesn't make any difference. I no longer go by how the bowl looks and check it on a schedule. Am using Napa 3039 filter with spring under it and have had no further fuel problems
california dean is offline   Reply With Quote
Old 08-16-2010, 07:17 PM   #9
V4F
V4F's Avatar
why the spring under it ?? the bowl traps it on the lip . ... steve
V4f
Old 08-16-2010, 09:12 PM   #10
california dean
ummmm, because it was there when I got the car and it looks cool? You're right, I'll take it out next time I have it apart. Thanks.
Old 08-17-2010, 06:09 AM   #11
skip
Banned
Why not just a can/paper fuel filter down stream of the settling bowl screen. More than good enough.
A good stock bowl screen already is OK enough me thinks.
Mine works great.
So what is a gas tank? It just holds what you put in it till you pour it out. This kind of a problem [silt] is not at the filter but in the tank.
skip.
skip is offline   Reply With Quote
Old 08-17-2010, 07:43 AM   #12
Ray64
Ray64's Avatar
I use a micro filter -but i also have a very clean fuel tank.I have had no problems for years. RAY
Ray64 is offline   Reply With Quote
Old 08-17-2010, 10:01 AM   #13
dfclimber
dfclimber's Avatar
For those of you that use the WIX filter or Nappa 3034- does it fit in standard glass sediment bowl/changed to larger sediment bowl or have you added it as an additional inline filter
dfclimber is offline   Reply With Quote
Old 08-17-2010, 10:14 AM   #14
1928Pickuppain
1928Pickuppain's Avatar
I run one in my 78 glastron and its has no problem.
1928Pickuppain is offline   Reply With Quote
Old 08-17-2010, 10:39 AM   #15
dfclimber
dfclimber's Avatar
1928pickuppain- does it fit inside your glass sediment bowl or do you have it inline between the sediment bowl and carb
