Old 05-08-2013, 12:20 PM   #1
Dune Country
Default what would Henry do
Just about finished with a nut and bolt restore of a '30 CCPU.
As I worked on the old girl I often thought if back when you did something to make Henry mad where would he put you on the assembly line.
My vote is rear window installer on the closed cab pickup line, what a task that was.
whats your thoughts?
Dune Country is offline   Reply With Quote
Old 05-08-2013, 12:31 PM   #2
Brentwood Bob
Default Re: what would Henry do
You were gone. Bob
Brentwood Bob is offline   Reply With Quote
Old 05-08-2013, 12:34 PM   #3
MikeK
MikeK's Avatar
He would take you off the assembly line and send you to the pouring and shakeout lines in the iron foundry.
MikeK is offline   Reply With Quote
Old 05-08-2013, 07:49 PM   #4
ScottNW/Ohio
ScottNW/Ohio's Avatar
Would be a better job than rear window installer on C/C pickups in '30-'31
That was one thing that was definately 'over engineered'
ScottNW/Ohio is offline   Reply With Quote
Old 05-08-2013, 08:54 PM   #5
SteveB31
SteveB31's Avatar
Never figured out WHY they used 24 bolts to install ONE window, and they used the same window and frame all the way thru 1931 on all closed cab pickups.
SteveB31 is offline   Reply With Quote
Old 05-08-2013, 09:35 PM   #6
Brentwood Bob
Do you resort to a cut off wheel on a die grinder for removal if they won't respond to a screwdriver????? Bob
Old 05-08-2013, 09:37 PM   #7
Art Bjornestad
Art Bjornestad's Avatar
My '31 ccpu has a different window than a '29
Art Bjornestad is offline   Reply With Quote
Old 05-09-2013, 09:23 AM   #8
Bruce Lancaster
Henry was a famous practical joker. Betcha he'd give you a nice, clean, easy job like installing the taillight, but give you only Vintique parts and hardware til you went mad!
Bruce Lancaster is offline   Reply With Quote
Old 05-09-2013, 02:04 PM   #9
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Took nearly a day to install one recently in a steel top 31 so I know what you're talking about. After all that work I looked the next day and the glass had cracked. Apparently there was a twist in the cab roof that put a strain on the glass. I ended up using a piece of lexan.
Barry B./ Ma. is offline   Reply With Quote
Old 05-09-2013, 04:27 PM   #10
roccaas
roccaas's Avatar
Or two days as Charles Sorensen's "gopher".
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
