Old 04-26-2013, 11:43 AM   #1
johnbuckley
johnbuckley's Avatar
Default Carb jet gaskets
on the Zenith...
1) Should there be a gasket between the body and the compensator jet?
2) Should there be a gasket between the body and the removable brass GAV seat?
johnbuckley is offline   Reply With Quote
Old 04-26-2013, 11:50 AM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Carb jet gaskets
There should be a jet gasket installed with the main jet, cap jet, comp jet, and GAV brass seat. There should not be a gasket installed with the idle jet as the threads are a pipe thread.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 04-26-2013, 11:52 AM   #3
johnbuckley
Thanks Tom. That must be the most rapid trans-Atlantic Q and A. Thanks!
Old 04-26-2013, 12:41 PM   #4
Benson
John,
A common problem is that some carbs end up with 2 or even 3 gaskets under the Main Jet. This lowers the Main jet and it does not work as designed. The M J should be taller than the Cap Jet as designed.
Good idea to use a flashlight or torch and check inside the M J "port" for extra gaskets when ever you install a gasket.
Many times the gasket sticks inside the casting and folks add another thinking that they lost the original gasket.
Benson is offline   Reply With Quote
