Old 04-19-2013, 12:38 PM   #1
green30coupe
green30coupe's Avatar
Default What do you use for speedometer lube?
What do you use for speedometer lube? I am replacing another entire cable assembly after 2 years. I used the very thin graphite oil sold by most of the suppliers on the last one, but would white lithium or some other grease be better?
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
Old 04-19-2013, 12:51 PM   #2
Smurkey
Smurkey's Avatar
Default Re: What do you use for speedometer lube?
Graphite powder works good for me.
Smurkey is offline   Reply With Quote
Old 04-19-2013, 12:53 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I put some grease in my left palm then drag the cable through it as I insert it back into the housing. I also give the housing a few squirts of oil as the cable goes in. I've always done it this way and never had a dry or broken cable.
Old 04-19-2013, 12:55 PM   #4
green30coupe
Tom,
Do you just use Mystik Jt6?
Disregard, Tom. I found your previous post by searching (as I should have done to begin with!)
Ed
Old 04-19-2013, 12:55 PM   #5
MikeK
MikeK's Avatar
I've always used 3% Moly lithium base grease in speedo cables. It's black, not white. Never had a replacement cable done with it fail. Your results may vary!
MikeK is offline   Reply With Quote
Old 04-19-2013, 01:21 PM   #6
H. L. Chauvin
For new cable, first used the recommended graphite in a tube -- appeared thin, so in addition, put a glob of white lithium grease on one end & pulled new cable through same -- probably won't live long enough to see it fail.
Speedometer was erratic, gear inside difficult to rotate when turned by hand -- removed hard caked grease inside & replaced with same white lithium -- gear now rotates freely.
H. L. Chauvin is offline   Reply With Quote
Old 04-19-2013, 01:28 PM   #7
tdlmomowers
tdlmomowers's Avatar
Flex shaft grease, that is used on string trimmers shafts works good. I get it at my lawn and garden equipment dealer.
tdlmomowers is offline   Reply With Quote
Old 04-19-2013, 01:41 PM   #8
FL&WVMIKE
FL&WVMIKE's Avatar
I have always used good ole VASOLINE. It does not get stiff in cold weather and it doesn't run when warm.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 04-19-2013, 02:46 PM   #9
RonC
RonC's Avatar
I had asked the Lubriplate Lubricants Company that question; What type of grease should be applied to automobile speedometer cables? There response was "we recommend LUBRIPLATE Aero".
RonC is offline   Reply With Quote
Old 04-19-2013, 02:56 PM   #10
AL in NY
AL in NY's Avatar
I use liquid graphite lock lubricant, flows through the cable end to end.
AL in NY
AL in NY is offline   Reply With Quote
Old 04-19-2013, 04:12 PM   #11
Tom Wesenberg
MIKE
That hasn't been my experience using Vaseline. I used to put it in all the light sockets (important for salt states) but when the bulb got warm the Vaseline would run all over the bulb. Now I use a high temp grease in the sockets.
Old 04-19-2013, 08:24 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I use Delco distributor cam lube. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-19-2013, 09:30 PM   #13
spdway1
spdway1's Avatar
I just replaced my Speedometer and cable on Wed., Should I have lubed the cable, it seems quiet.
spdway1 is offline   Reply With Quote
Old 04-20-2013, 02:00 AM   #14
Tom Wesenberg
Yes, I'd pull it back out and lube it.
Old 04-20-2013, 02:31 AM   #15
green30coupe
I would definitely pull it back out and lube it. Any lube would be better than running it dry.
Ed
