Old 04-19-2013, 01:41 PM   #1
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: What do you use for speedometer lube?
I have always used good ole VASOLINE. It does not get stiff in cold weather and it doesn't run when warm.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 04-19-2013, 04:12 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
MIKE
That hasn't been my experience using Vaseline. I used to put it in all the light sockets (important for salt states) but when the bulb got warm the Vaseline would run all over the bulb. Now I use a high temp grease in the sockets.
