Old 03-23-2013, 01:38 PM   #1
FEO (UGLY)
FEO (UGLY)'s Avatar
Default Flathead
City: Henderson
State: nv
Price: 350.00
1932-1937 complete ford flathead. needs rebuilt. dist. is not correct. asking $350.00 obo maybe be available to help with shipping call 702-249-1397
FEO (UGLY) is offline   Reply With Quote
Old 03-24-2013, 12:53 AM   #2
G32
Default Re: Flathead
Handsome FEO
Pen engine down to 33/34(non ventilated) or 35/36(ventilated).
35/36 have 1.5" tube in rt front of valve chamber down thru eng to pan rail &
Zippo cig lghter size tin vent can below on rt front of oil pan.
Need more info re numbers on heads, etc. For a start to id. Main bearings
next if 1936.
Gene Tulsa
G32 is offline   Reply With Quote
Old 03-30-2013, 03:56 PM   #3
FEO (UGLY)
FEO (UGLY)'s Avatar
num. on back of block reads 160 24
Old 03-30-2013, 08:45 PM   #4
Andy
Trans mount is 35-36. The pan is not 32-34 so probably also 35-36. It looks like a truck engine from the fan. I think the trans top changed in 36 so I call it a 35.
Andy is offline   Reply With Quote
Old 03-30-2013, 09:06 PM   #5
Barn Junk
Barn Junk's Avatar
Don't I see water pump cover plates on the block making it a 1937?? Also I see a somewhat valuable Stromberg carb.
Barn Junk is offline   Reply With Quote
Old 03-31-2013, 12:55 AM   #6
G32
Feo
Per Barn man appears to be water pump in block 37/38 engine --confirm front block-off plates where pumps should mount.
Is running 36 & earlier water pump in heads. Distributor is correct for 37-41.
Probly in 35/36 auto or 1/2 t commercial-l trans is not truck best I see. Gene Tulsa
Old 04-01-2013, 11:58 PM   #7
FEO (UGLY)
FEO (UGLY)'s Avatar
Sold
