11-15-2010, 08:47 AM | #61 | |
Re: Engine Hard To Start Question
I am begining to lose sleep over this problem. Thanks for all the help and ideas Bob |
11-15-2010, 10:34 AM | #62 |
I hear you Bob, also might check the wire under the dist plate that goes to the points, I had one gounding out. Also I would pickup a model a cap, wires, and rotor (cheap) makes timing easier and looks like a model a.
11-15-2010, 12:38 PM | #63 | |
11-15-2010, 01:47 PM | #64 |
I do not think you are going to believe this but after trying all the suggestions related to spark and having no success I opened the carburetor. You may remember that I had it rebuilt and had returned it once and was I told that the float had a leak. When I opened it this morning I found that the venturi was broke into two pieces and when reassembling the halves they double gasketed the mating surfaces and applied a blob of silicon on the two halves in hope of sealing the venture. Needless to say the silicon was not gas resistant and I have little pieces of silicon floating in the carburetor, not to mention that the venturi is non functional.
I have contacted the rebuilder this morning and he has been apologetic and vowed to get back to me in the next few hours. &#^%)@##* |
11-15-2010, 02:04 PM | #65 |
Except for the 1928 double venturi, they are cheap and there's no reason to try to use a broken one. I'd rebuild it yourself. That way you know what you have.
11-15-2010, 02:51 PM | #66 | |
Joe
1929 Tudor since 1962 Feather River A's |
11-15-2010, 03:20 PM | #67 |
okaydoki,
well look at it this way you learned alot and you may sleep tonight. |
11-15-2010, 03:25 PM | #68 |
The effort was not in vain as I now know something about the electrical system and something about a certain carburetor rebuilder.
Thanks to everyone who helped me with the lesson. Bob |
11-15-2010, 04:34 PM | #69 |
yayaaa told ya you would get it mastered. So I guess the saying sticks... Just because it was rebuilt doesn't mean it was rebuilt right!!!
11-15-2010, 06:26 PM | #70 |
11-15-2010, 06:47 PM | #71 |
Good for you and your tenacity. Big question: are we running yet? Let us know. I've learned a lot from this thread.
Paul in CT |
11-15-2010, 06:53 PM | #72 | |
Thanks Bob |
11-17-2010, 01:27 PM | #73 |
A friend came by today with the carburetor off his Model A. My engine was hard to start but it did start and run. The only problem was that it did not accelerate well. When I depress the accelerater it tends to bog down. At least I know the engine will run. Now I need to resolve the accelaration issue. My carburetor should be back early next week and I can continue my project of getting the engine to run. In the meantime I am lookig for another Zenieth core so I can rebuild it myself.
I will keep you posted. Thanks for all the help thus far Bob |
11-17-2010, 01:40 PM | #74 |
Sounds like it is too retarded. Did you remember to pull the advance lever down?
11-17-2010, 01:43 PM | #75 |
11-17-2010, 06:55 PM | #76 |
Do you have the carb book that Steve Pargetter wrote? It has lots of good information for anyone wanting to work on the carb, and it's very reasonably priced.
11-17-2010, 07:17 PM | #77 |
Did you play with the fuel mixture?
11-17-2010, 07:32 PM | #78 |
11-17-2010, 07:37 PM | #79 |
I did but I am not sure it had any effect. Possibly because I am not sure what to do. I started it at about one turn from bottom and move it back and forth about 1/2 turn in both directions. It had little effect. The engine sounded great and it did not smoke. I have found and purchased a compression gage that will fit the 7/8 diameter plug hole. I will get it later this week |
11-17-2010, 07:41 PM | #80 |
On mine it will bog if it's open to much.
