Old 11-15-2010, 08:47 AM   #61
Bob Grieb
Bob Grieb's Avatar
Send a message via Yahoo to Bob Grieb
Default Re: Engine Hard To Start Question
Originally Posted by Mitch//pa View Post
take a simple 12volt test light and see if your losing power to the coil when you lose spark.
I will try this this morning. I did jump the ignition switch yesterday and it made no difference. I know that the ampmeter is not working so I will try jump it this morning as well.
I am begining to lose sleep over this problem.
Thanks for all the help and ideas
Bob
Bob Grieb is offline   Reply With Quote
Old 11-15-2010, 10:34 AM   #62
IrishHills
IrishHills's Avatar
Bob
I hear you Bob, also might check the wire under the dist plate that goes to the points, I had one gounding out. Also I would pickup a model a cap, wires, and rotor (cheap) makes timing easier and looks like a model a.
IrishHills is offline   Reply With Quote
Old 11-15-2010, 12:38 PM   #63
Tom Wesenberg
Tom Wesenberg's Avatar
Bob
The easiest way to jump the amp guage is to just jump across the two wingnuts on the terminal box cover. Of course, the connections under the terminal box lid still must be clean and tight for this jump to work.
Old 11-15-2010, 01:47 PM   #64
Bob Grieb
Bob Grieb's Avatar
I do not think you are going to believe this but after trying all the suggestions related to spark and having no success I opened the carburetor. You may remember that I had it rebuilt and had returned it once and was I told that the float had a leak. When I opened it this morning I found that the venturi was broke into two pieces and when reassembling the halves they double gasketed the mating surfaces and applied a blob of silicon on the two halves in hope of sealing the venture. Needless to say the silicon was not gas resistant and I have little pieces of silicon floating in the carburetor, not to mention that the venturi is non functional.
I have contacted the rebuilder this morning and he has been apologetic and vowed to get back to me in the next few hours.
Old 11-15-2010, 02:04 PM   #65
Tom Wesenberg
Except for the 1928 double venturi, they are cheap and there's no reason to try to use a broken one. I'd rebuild it yourself. That way you know what you have.
Old 11-15-2010, 02:51 PM   #66
JoeWay
JoeWay's Avatar
[...and I have little pieces of silicon floating in the carburetor...
...and, no doubt, plugging jets and passages and leading to fuel starvation.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 11-15-2010, 03:20 PM   #67
Mitch//pa
okaydoki,
well look at it this way you learned alot and you may sleep tonight.
Old 11-15-2010, 03:25 PM   #68
Bob Grieb
Bob Grieb's Avatar
The effort was not in vain as I now know something about the electrical system and something about a certain carburetor rebuilder.
Thanks to everyone who helped me with the lesson.
Bob
Old 11-15-2010, 04:34 PM   #69
bogdonj
bogdonj's Avatar
yayaaa told ya you would get it mastered. So I guess the saying sticks... Just because it was rebuilt doesn't mean it was rebuilt right!!!
bogdonj is offline   Reply With Quote
Old 11-15-2010, 06:26 PM   #70
Bob Grieb
Bob Grieb's Avatar
Now how could I argue with that logic?
Old 11-15-2010, 06:47 PM   #71
1931 flamingo
1931 flamingo's Avatar
Good for you and your tenacity. Big question: are we running yet? Let us know. I've learned a lot from this thread.
Paul in CT
Old 11-15-2010, 06:53 PM   #72
Bob Grieb
Bob Grieb's Avatar
Paul in CT
Paul - I am not running yet as I have need of a carburetor. I contacted the rebuilder and they were very apologetic and I am shipping the unit back to them but I am trying to get another core that I plan to rebuild myself.
Thanks
Bob
Old 11-17-2010, 01:27 PM   #73
Bob Grieb
Bob Grieb's Avatar
A friend came by today with the carburetor off his Model A. My engine was hard to start but it did start and run. The only problem was that it did not accelerate well. When I depress the accelerater it tends to bog down. At least I know the engine will run. Now I need to resolve the accelaration issue. My carburetor should be back early next week and I can continue my project of getting the engine to run. In the meantime I am lookig for another Zenieth core so I can rebuild it myself.
I will keep you posted. Thanks for all the help thus far
Bob
Old 11-17-2010, 01:40 PM   #74
tuneman
tuneman's Avatar
Sounds like it is too retarded. Did you remember to pull the advance lever down?
tuneman is offline   Reply With Quote
Old 11-17-2010, 01:43 PM   #75
Bob Grieb
Bob Grieb's Avatar
Thanks - I did try that and the engine smoothed out and the RPM increased but it still bogged down when I tried to accelerate.
Bob
Old 11-17-2010, 06:55 PM   #76
Tom Wesenberg
Do you have the carb book that Steve Pargetter wrote? It has lots of good information for anyone wanting to work on the carb, and it's very reasonably priced.
Old 11-17-2010, 07:17 PM   #77
IrishHills
IrishHills's Avatar
Bob
Did you play with the fuel mixture?
Old 11-17-2010, 07:32 PM   #78
Bob Grieb
Bob Grieb's Avatar
I do not have that book. I will have to look for it. Any idea where I can find it?
Thanks
Bob
Old 11-17-2010, 07:37 PM   #79
Bob Grieb
Bob Grieb's Avatar
I did but I am not sure it had any effect. Possibly because I am not sure what to do. I started it at about one turn from bottom and move it back and forth about 1/2 turn in both directions. It had little effect.
The engine sounded great and it did not smoke.
I have found and purchased a compression gage that will fit the 7/8 diameter plug hole. I will get it later this week
Old 11-17-2010, 07:41 PM   #80
IrishHills
IrishHills's Avatar
On mine it will bog if it's open to much.
