11-13-2010, 01:32 PM | #41 |
Re: Engine Hard To Start Question
I am using fresh gas and I have verified good flow to the carburetor. I know little about the carburetor. I had it rebuilt and had to return in once because the float had a pin hole in it. I am thinking that the spark is not the issue.
11-13-2010, 01:42 PM | #42 | |
this sounds like a fuel problem...carb, fuel flow, leaky manifold, stuck valves, etc since you are in Temecula, which has a club with around 90 members, it would probably be easier with some hands on help, which might be easy to get with a phone call. Try a proven good carburetor and see how that works. Did you do a compression check? |
11-13-2010, 01:45 PM | #43 |
If holding the choke half way out allows it to run longer, that certainly points to a fuel problem.
I would look for, in no particular order, really bad fuel, no air flow into the tank due to a clogged or missing gas cap vent, a rust clogged or bad fuel shut off valve, a clogged fuel line, a clogged sediment bulb, clogged carburetor jets, or some other carburetor problem. |
11-13-2010, 01:56 PM | #44 |
Pat
After posting as a Newbie and receiveing the recommendation to get involved in a Model A Club I went on line and got the information and I am going to attend my first Model A meeting this coming Tuesday. Thanks Bob |
11-13-2010, 02:02 PM | #45 |
I would suspect that if you contact the local club, you will easily find someone who will stop by and help you get the problem solved. Years ago, I had someone from my local club stop by and help me with a problem. These days, I am one of the guys who stops by and helps others when they have problems.
11-13-2010, 02:14 PM | #46 | |
11-13-2010, 02:33 PM | #47 |
Thanks
I will get the timing scale. I need to get it to run first. Hopefully soon. Bob |
11-13-2010, 02:47 PM | #48 |
Ok Bob, I was the poster of the thread mentioned above about our A not running just like what you have mentioned. I have tried everything for weeks to get the thing running. I ended up taking it back to our rebuilder and he took the spark plug leads off the distributor and cranked it over and success it started right up. Our rebuilt carb was the issue. For some reason it was always running rich even when the adjustment was turned off and it was fouling our plugs. Not 1 but all 4 at the same time. Here is a video of it starting with the spark plug leads off. Try this and see if she will run!!!! It sure shocked me and I was lost for words. Just because it was rebuilt doesn't mean it was rebuilt right or working right. Give it a try and let me know! Before trying this take your plugs out and make sure they are dry and clean.
https://www.youtube.com/user/bogdonav.../3/NquVJtQCOo4 --Video My post regarding NO START http://fordbarn.com/forum/showthread.php?t=16974 Justin |
11-13-2010, 03:22 PM | #49 | |
11-13-2010, 05:16 PM | #50 |
Check the timing specs. for the dissy with a MODERN cap. My thought the idle circuit in the carburetor is clogged.
11-13-2010, 08:12 PM | #51 |
If it starts to die give it a quick pull of the choke. You may have to this two or three times till everything gets working smoothly. This method works foir me!
11-14-2010, 12:28 AM | #52 | |
if they don't have the time, they'll give you someone's number who just might. It is the weekend, and Model A folks are quite generous with their help. Someone in your area might be bored and need to get out of the house. I suspect the "rebuilt" carburetor has some issues. Its easier for you to install another that is known to work to eliminate or confirm the carb as the problem than it will be to diagnose the carburetor. |
11-14-2010, 12:40 AM | #53 |
Thanks for the advice Pat. Iam going to a tractor auction tomorrow so iwill contact someone early Monday morning. I agree it would be simpler to put a known good carburetor on the engine rather than trying to find an issue with he present carb
Bob |
11-14-2010, 09:47 PM | #54 |
I spent most of the afternoon trying to get the A to run with little success. I retimed it and toward the end or the day I noticed that the spark at the plugs is intermitent. It appears that when I first turn the engine ove I have spark but within a few seconds the spark disappears. Does that sound possible?
If I chose to by a new coil do i have to get one specific to the Model A or is a 6 volt coil a six volt coil. Bob |
11-14-2010, 10:19 PM | #55 | |
11-14-2010, 10:24 PM | #56 |
take a simple 12volt test light and see if your losing power to the coil when you lose spark.
11-14-2010, 10:29 PM | #57 |
here is a diagram if you need it
11-14-2010, 10:29 PM | #58 |
Also take a jumper wire, remove the instument panel screws, and jump across the ignition switch if it's a repro. See if that doesn't help.
11-14-2010, 10:35 PM | #59 |
11-15-2010, 01:30 AM | #60 |
Sounds like it is the coil, ignition switch, battery, or the condensor.
Dennis L Oberer Green Bay WI |
