Old 06-26-2014, 10:41 PM   #61
Mr. Will
Mr. Will's Avatar
Default Re: 1935 Ford Juice Brakes
Got my wheels back from the powder coater today, had the tires mounted and sat her back down on the ground.
Mr. Will is offline   Reply With Quote
Old 07-01-2014, 07:47 PM   #62
Mr. Will
Mr. Will's Avatar
Ran it 230 miles this past weekend and it all work just fine.
Old 07-01-2014, 09:12 PM   #63
JM 35 Sedan
JM 35 Sedan's Avatar
Nice work! Looking good. Does your car have a rumble seat or a trunk?
John
Old 07-01-2014, 11:57 PM   #64
Mr. Will
Mr. Will's Avatar
It has a trunk
Old 07-02-2014, 02:56 AM   #65
Mart
Mart's Avatar
Re the clutch pedal hitting the frame. My 40 frame had a sort of recess where the x-member leg meets the frame. this allows a little more travel before the pedal bottoms out. I don't know if the 39 had this, or if the 35 frame has it, but if the pedal is hitting the frame, that might be what is causing it.
Edit: I just saw you ran it and it is fine. that's good. Did you do anything to the clutch pedal? Or was there sufficient travel as it was?
Mart.
