#21 |
#22 |
I don't know what you are saying James. I'm not disrespecting the 2.3, just that many were put in Pintos, after the 2000cc engine. I am putting a dual plug head engine back together as well at this time. Mine , at 201K miles " tuliped" an intake valve. But its been a good engine. Not sure why you call it Mazda, it was first built by Ford of Europe.
Pete's Ponies Mustang RUSToration & Performance Last edited by PetesPonies; 12-08-2012 at 09:43 AM. |
#23 | |
![]() Quote:
#24 |
I know Mazda used it as well, but it was designed by Ford of Europe and used for many years before it ever saw a Mazda. Ford did a lot of trading of engines and cross designing with Mazda , that they own a large stake in , but the Ford 2.3 could hardly be called a Mazda engine. The 2.3 that was used in Rangers after the SOHC 2.3 was dropped, is all Mazda. But that's another engine intirely.
Pete's Ponies Mustang RUSToration & Performance |
#25 | |
![]() Quote:
#26 |
#27 |
From wikipedia.
Lima OHC (LL) 2.3 (LL23) The Ford Pinto used the OHC version, a 2.3 L (2302 cc) unit introduced in 1974 which has a 96.0 mm (3.78 in) bore and 79.5 mm (3.13 in) stroke. This version lasted until 1997 in various guises. The earliest units produced 66 kW (88 hp) and 160 N·m (118 lb·ft). This engine has also been known as the Lima engine, after the Lima Engine plant in Lima, Ohio, where it was first manufactured (it was also later manufactured in Brazil). In 1979-80, a draw-through, non-intercooled turbo version was produced for Mustang Cobras and some Capris. Lack of dealership and owner training resulted in many stuck turbochargers and other maintenance problems. They were limited to 5 PSI of boost though Ford Motorsport sold a wastegate with an adjustable rod which allowed an increase of up to 9 PSI. It was used in this carbureted form in a number of passenger cars, from the Fairmont Futura Turbo to the 1979 Indy Pace Car edition Mustang. In the 1980s, a turbocharged and intercooled version was used in the Ford Thunderbird Turbo Coupe. This was made practical by the introduction of Ford's EECIV port fuel injection system; 1983's 2.3 Liter Turbo was the first production implementation of that advance in technology, which paved the way for across the board use in many Ford passenger car; however, the turbo version never made it into any Ford trucks. Output for this turbo/intercooled version was 142 kW (190 hp) and 325 N·m (240 lb·ft) for the 1987-88 models with the (T-5) 5-speed manual transmission. The turbocharged and intercooled 2.3 was also used in the 1984-86 Mustang SVO, while the 1983–1984 Mustang TurboGT, 1985-89 Merkur XR4Ti, 1983–1986 Thunderbird Turbo Coupe and 1984–1986 Mercury Cougar XR7 all skipped the intercooler on their turbo versions, which dropped output to 155 hp (116 kW) and 205 ft·lbf (278 N·m) of torque. The SVO Mustang's output increased in 1985½ to 205 HP. A dual-spark version (with two spark plugs per cylinder and distributor-less ignition) was introduced in the 1989 Ford Ranger and 1991 Ford Mustang. This version produced 78 kW (105 hp) and 183 N·m (135 lb·ft). Applications:
A stroked (by 7 mm) version of the 2.3 OHC Ford Ranger engine appeared in 1998. It also used higher-flow cylinder heads for better intake and combustion. Output was 89 kW (119 hp) and 202 N·m (149 lb·ft). It was replaced in 2001 by the Mazda-derived Duratec 23, but Ford Power Products continues to sell this engine as the LRG-425. Applications:
#28 |
