Old 06-30-2014, 11:45 PM   #21
Barber31
Barber31's Avatar
Default Re: Has Anyone Put A Radio In There 6 Volt Car
I bought mine from macs or snyders. But I think they both carry it. I was just looking for the better price. It's listed under power inverter in the index I think. I believe it was $98 bucks
Barber31 is offline   Reply With Quote
Old 07-01-2014, 12:00 AM   #22
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by Ken B View Post
I looked on Ebay and didn't see the 6VDC to 12VDC converter. Does anyone have a link to one?
It's from China,
http://www.ebay.com/itm/Industry-Gra...-/221182096801
Old 07-01-2014, 12:26 AM   #23
ModelAMike1930
ModelAMike1930's Avatar
I got a cube radio from Menards its a SuperSonic Model SC-1325 its FM also has a usb port so you can use a flash drive with pre-recorded music or an sc drive. The provided usb cord acts as an antenna.
ModelAMike1930 is offline   Reply With Quote
Old 07-01-2014, 12:27 AM   #24
ModelAMike1930
P.S. the radio has a builtin battery that you can charge off your computer..
Old 07-01-2014, 12:42 AM   #25
Harley03joe
Harley03joe's Avatar
Smile Re: Has Anyone Put A Radio In There 6 Volt Car
All Very Good Comebacks , I'LL Use A Portable Raido
And Be Happy
Thank You All For Your Feed Backs
Just Got My 31 This Morning From LA And It Like New
Thanks Again
Harley03joe
Harley03joe is offline   Reply With Quote
Old 07-01-2014, 01:05 AM   #26
Harley03joe
Thanks Mike I Just Got One >>> SuperSonic Model SC-1325 Saves A Lot Of Problems
Harley03joe
Old 07-01-2014, 06:37 AM   #27
29 Tudor
29 Tudor's Avatar
If you do an fleabay search for "6 to 12 volt converter" you will find several 6 to 12 volt converters. For some reason, the one I used is now priced at $99.75 when I paid something like $4.99 for it. I suspect their pricing is wrong. Anyway, that will give you an idea of where I found mine. Might drop them a note and ask if the price is wrong.
The vendor (coldfusionx) lists some other converters as well for much less.
Steve
29 Tudor is offline   Reply With Quote
Old 07-01-2014, 07:07 PM   #28
Kevin in Utah
I had a radio guy put a 1934 Motorola NOS in my Model A pickup in about 1971. It runs with control cables and is hanging upside down between the gas tank and the top of the steering column. It works good for AM. I don't know what I will do, when a tube goes. I may switch over to a 6 volt Volkswagen. I bought a real expensive gizmo that goes between the antenna wire to plug in my IPod, but the impedance or something like that causes interference. It cost $150.00 what a waste of $. If you do get a radio; you will need a spark suppressor on the coil wire. I saw some on Ebay for a lot of money. I hope this helps.
Kevin in Utah is offline   Reply With Quote
Old 07-01-2014, 07:11 PM   #29
FrankWest
FrankWest's Avatar
Originally Posted by SDJason View Post
Well - here's the 6V radio I put in. It's currently running off of (4) AA batteries, but I plan to wire it into the car's power at some point. Do you get electrical interferance from the sparks and distributer?
It's a Crosley CR-82; if you look, they turn up on ebay or etsy every so often, usually for around $20-$30.
Hey that is a nice idea. Is is new but has the same over all look as nastalga.
I bought an original ford 1933 car radio 6 volt with tubes that I will be installing in a 1933 ford glove box. I have to instal ressitors on the spark plugs and generator to reduce radio interference.
FrankWest is offline   Reply With Quote
Old 07-01-2014, 08:56 PM   #30
Bigdave
Bert's and other suppliers have ihe inverters.
Bigdave is offline   Reply With Quote
Old 07-01-2014, 10:02 PM   #31
SDJason
SDJason's Avatar
The FM works fine, I've never tried AM.
I actually hardly ever use it - it's really there for kicks and giggles when I have friends or acquaintances riding in the car.
I keep an iPod hooked up to a FM transmitter ($15 at Wally World) in the car at all times - it's loaded up with 1920s-1930s tunes (and a few Glenn Miller songs as well).
SDJason is offline   Reply With Quote
Old 07-01-2014, 10:18 PM   #32
Dick Webber
In the 60s when it was my daily driver I rigged up a 6V 52 Chevy car radio in my 29 tudor. It sat in the back seat floor and the antenna was mounted on the left rear window glass with a homemade clamp bracket. (The glass still has the scratches). And yes, ignition noise was a problem. Seems like I had some kind of suppressor but it was still noisy. Crude and cheap, but it worked.
Dick Webber is offline   Reply With Quote
Old 07-05-2014, 04:48 PM   #33
sconnors
sconnors's Avatar
Found this cool looking "retro" radio that has an input for an iPod. So I have it hanging by the rearview mirror and my iPod hidden and a bunch of 1930's tunes playing while I drive.
sconnors is offline   Reply With Quote
Old 07-06-2014, 04:20 PM   #34
stewwolfe
stewwolfe's Avatar
MP3 player with ear buds (or in my case Bluetooth hearing aids) works just fine for me. If I get sick of my music, I can tune in FM radio on it (like $25.00 at WalMart).
stewwolfe is offline   Reply With Quote
Old 07-08-2014, 12:14 AM   #35
Harley03joe
Ok Mike I Got My Cube Radio SuperSonic Mod.SC1325
And Put A Lexar 32 GB Micro SDHC Chip In It Now The Question Is How Do I Put My Songs On It ? I Have It Pluged In To The Computer And I Dont See Any Drive To Transfer Song To, Need A Little Help Ok
Thanks
Harley03joe
Old 07-09-2014, 04:49 PM   #36
kingbee
kingbee's Avatar
Send a message via AIM to kingbee
Joe
Remove the chip and connect it to your computer. Then simply drag and drop the music you like to the chip.
kingbee is offline   Reply With Quote
Old 07-09-2014, 05:07 PM   #37
Harley03joe
Originally Posted by kingbee View Post
Joe
Ok I Done That,, I'm All Set Now, That Little Radio Works Great
Thank You
Harley03joe
Old 06-21-2024, 04:51 PM   #38
Zoltan
Zoltan's Avatar
My dad installed a Motorola 309 in our 31 coupe, an all-in-one aftermarket unit from 1950, AM only, 6-volt, positive ground. I recently replaced all the capacitors and got it working.
File Type: jpg Motorola 309 AM radio 6V Universal 1949-50.jpg (11.6 KB, 23 views)
Zoltan is offline   Reply With Quote
Old 06-21-2024, 08:17 PM   #39
rfitzpatrick
YES -- I had one made using a '32 Philco Control Head that sets on my steering shaft just like then. Unfortunately, the owner of that company pasted away. I have photo's and the name of another firm that'll take any control head and adapt it to the new transistor. I also have a collection of controllers for this purpose. I can gift you one, but I'm only able to deal with e-mail, I see you decline contact. I'm not interested in selling the controllers, but can offer to gift you a choice. I used a meganitc antenna.
rfitzpatrick is online now   Reply With Quote
Old 06-22-2024, 07:46 AM   #40
Bob Bidonde
Bob Bidonde's Avatar
Many many moons ago, I put a 6V car radio into my 45B Coupe. Listening to tunes was not enjoyable because of the car's running noise and static from the ignition. Using a head set would have eliminated the car noise, but eliminating the ignition static would have required shielding & electrical filtering. I tried mimicking the Chevy Corvette's radio shielding, but it was hopeless so the radio was discarded.
I suggest that you use a cell phone with ear speakers.
Bob Bidonde
