Old 06-29-2014, 02:48 PM   #1
Harley03joe
Harley03joe's Avatar
Default Has Anyone Put A Radio In There 6 Volt Car
Has Anyone Put A Radio In There 6 Volt Car ? 1931 Ford Mod A
If So , Was It 6 Volt And What Brand Was It ? Pictures Will Be Very Helpful Or Any Suggestions
Thank You
Harley03joe
Harley03joe is offline   Reply With Quote
Old 06-29-2014, 03:31 PM   #2
SDJason
SDJason's Avatar
Default Re: Has Anyone Put A Radio In There 6 Volt Car
Well - here's the 6V radio I put in. It's currently running off of (4) AA batteries, but I plan to wire it into the car's power at some point.
It's a Crosley CR-82; if you look, they turn up on ebay or etsy every so often, usually for around $20-$30.
SDJason is online now   Reply With Quote
Old 06-29-2014, 04:51 PM   #3
Jeff in BC
Jeff in BC's Avatar
This may be a little modern but would work http://www.ebay.ca/itm/vintage-car-r...p2056016.l4276
Jeff
Jeff in BC is offline   Reply With Quote
Old 06-29-2014, 06:32 PM   #4
29 Tudor
29 Tudor's Avatar
You can find a converter on fleabay that converts 6V to 12V for about $5.00. I bought one that was good for 18 watts.... that's 1.5 amps at 12 volts. If you are under that with your radio, you can use a 12 volt auto radio and it makes it pretty simple. I used mine for a 12 volt third brake light. Works great!
Steve
29 Tudor is offline   Reply With Quote
Old 06-29-2014, 07:05 PM   #5
Fred K-OR
Fred K-OR's Avatar
Steve
I did the same thing for a GPS. But I ended up burning out two 12 volt plugins for the GPS before I thought about + and -. That is I had them hooked up wrong and things don't work to well that way. Typical for this old guy working on his A.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 06-29-2014, 07:15 PM   #6
29 Tudor
29 Tudor's Avatar
Yup, that old + and - stuff will get you! The ones I got weren't plug ins and I wired them directly into the circuit. Work great as long as you don't need more power than they will deliver. At 18 watts, you would need a small heat sink with the ones I used but you can find them with the heat sink included.
sd
Old 06-29-2014, 07:27 PM   #7
glenn in camino
glenn in camino's Avatar
Model A sounds are much more pleasant than what's on the radio.
Old 06-29-2014, 07:33 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I agree.
The power antenna quit working on my modern car a month or two back, and I don't even miss that radio.
Old 06-29-2014, 08:01 PM   #9
machine girl
Put Sirius xm radio in one of our As ,the best. 100+ stations and no comercials.
machine girl is offline   Reply With Quote
Old 06-29-2014, 08:38 PM   #10
Tom Wesenberg
My friend has that in his newer car, and it is nice. It's the only radio station worth listening to in the Twin Cities, since we don't have even one station that plays 1962 and older tunes.
Old 06-29-2014, 08:49 PM   #11
newshirt
newshirt's Avatar
Consider using iHeartRadio on your smartphone and keeping the A unmolested by ugly wires. Or, download a bunch of CD's and listen to them.
Along those lines... this weekend I saw a Model A that had been wired up with a CB Radio, big whip antennae, cassette tape player and speakers -- all 80's vintage -- with nice 80's wood paneling. Some grandkids in the car did not know what those "vintage" devices were for. I had to explain. They just said, "whatever..." and pulled out their phones and ear buds.
Ray White
newshirt is offline   Reply With Quote
Old 06-29-2014, 10:14 PM   #12
Spokes
When I bought my 29 p.u. It had a 6volt Chevy tube radio it worked great. The only thing I didn't like is they mounted the antena on the side of the truck cab. I would have hidden the antena !!!
Spokes is offline   Reply With Quote
Old 06-29-2014, 10:33 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
A big problem with a radio in a model a is AM. There is a bunch of ignition noise. As mentioned a modern radio with a 6 to 12 v converter and a "hot Rod" hidden antenna that goes under the running boards will work.
Old 06-30-2014, 01:42 AM   #14
DougVieyra
DougVieyra's Avatar
Yes, radios in Model A's were common enough in the 1950's. I got mine from a 6 volt car from England - I forget the marque. The 6-volt radios from the VW beetle (aka "Bug") were used at least until my 1966). The radio housing itself, was under the seat. The antenna was either attached to the driver's outside cowl, or, as mine (and many others) - under the running board. The radio "Head" was attached to the steering column, with cables that ran down to the radio box under the seat.
DougVieyra is offline   Reply With Quote
Old 06-30-2014, 02:27 AM   #15
Mike V. Florida
Sapphire is the name of the radios used in the bugs.
Old 06-30-2014, 07:42 AM   #16
Barber31
Barber31's Avatar
Just finished wiring up my radio last night. Bought that power converter, turns +6 to -12. I'm using a brand new pioneer radio. The wiring is all hidden in the storage under the seats. It seems to work good so far.
Barber31 is offline   Reply With Quote
Old 06-30-2014, 09:08 AM   #17
KGBnut
KGBnut's Avatar
I got an old pair of powered computer speakers that were 6 volt. I put them on the package tray and plug in my mp3 player. At events were they just don't look right, I undo two plugs and they are gone.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 06-30-2014, 01:54 PM   #18
jthomas6
jthomas6's Avatar
I decided to just keep it simple. It gets AM/FM plus I can plug it into my computer and transfer a bunch of my 50's and 60's songs for replay any time I want to reminisce.
jthomas6 is offline   Reply With Quote
Old 06-30-2014, 08:15 PM   #19
Ken B
Ken B's Avatar
I looked on Ebay and didn't see the 6VDC to 12VDC converter. Does anyone have a link to one?
Ken B is offline   Reply With Quote
Old 06-30-2014, 08:19 PM   #20
Tom Wesenberg
Do a search for "inverter" and something should come up.
I'll also try to find a link to one.
