Old 09-15-2014, 03:36 PM   #1
JM 35 Sedan
JM 35 Sedan's Avatar
Default Need some help identifying this radiator
A friend has asked me to help identify this radiator (year & model) for him. Any help would be most appreciated. Thank you fordbarners
John
Old 09-15-2014, 03:47 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Need some help identifying this radiator
Doesn't look like any of the Fords most of "us" play with. MAYBE F-1? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-15-2014, 04:02 PM   #3
fordscript
fordscript's Avatar
I reckon its a late 35 car radiator.....that has had the top pipes changed, the filler fitted with another type of filler, and the 'raised' piece in the front center that has the overflow pipe come out of has been blanked off.
fordscript is offline   Reply With Quote
Old 09-15-2014, 04:39 PM   #4
Barry-ct
Barry-ct's Avatar
Definitely not an F-1 radiator. not 48-52 anyway.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 09-15-2014, 04:53 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
COE? Dd
T5 W/TORQUE TUBE
Old 09-15-2014, 04:58 PM   #6
JM 35 Sedan
Originally Posted by fordscript View Post
I reckon its a late 35 car radiator.....that has had the top pipes changed, the filler fitted with another type of filler, and the 'raised' piece in the front center that has the over]flow pipe come out of has been blanked off.
I also first thought it might be a late '35 passenger car radiator, and maybe it is, but a lot would have had to been changed. Here are some pictures of a couple late stock/original '35 radiators that I have.
John
Old 09-15-2014, 05:14 PM   #7
V8ER
Are there any numbers on the outlet side of the top tank?
V8ER is offline   Reply With Quote
Old 09-15-2014, 05:21 PM   #8
JM 35 Sedan
I can check for numbers on my two, but the other radiator that's in question, is 60 mile away in PA. If I find numbers on mine, I can call the owner of the one in question and have him check.
Up date..... just enlarged the above pictures of my two radiators and can see "B4". Can't see any numbers on his radiator in first post, but they are not the best pictures.
John
Old 09-15-2014, 06:15 PM   #9
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
It looks like the 39 pickup rad I have on my test stand except my has the filler cap in the middle of the top. Walt
Old 09-15-2014, 06:22 PM   #10
Brian
Brian's Avatar
My thoughts mirror those of fordscript.
Old 09-15-2014, 07:51 PM   #11
38 coupe
38 coupe's Avatar
That doesn't look like the 38-39 pickup radiator I have in the rafters. I too think it is an early radiator with the top tank modified quite a bit.
Old 09-15-2014, 08:23 PM   #12
39wdy
I think Walt's close but not a pickup radiator as it does not have the extended tank that sticks out over the fan. However, it does look a lot like a 39 car radiator I had which did not have the split core or a hole for the crank to fit through. I actually still have one of the split core radiators with a cap off to the side like the one pictured. I know we are used to seeing the radiator caps in the top center of the radiator and certainly some accommodation for the hand crank but what would a Ford part be if it weren't for the baffling variations in which they appear. Could be period correct but not necessarily a Ford product, perhaps a replacement part provided by one of the Ford suppliers. Toby
39wdy is offline   Reply With Quote
Old 09-16-2014, 09:26 AM   #13
DD931
DD931's Avatar
I would expect the year/series designator to be pressed into the top tank.
DD931 is offline   Reply With Quote
Old 09-16-2014, 10:54 AM   #14
Bob C
Could it be an early (35) radiator with the inlets changed to run
a later engine with the water outlets in the center of the head in
an early car??
Bob
Old 09-16-2014, 12:37 PM   #15
V12Bill
V12Bill's Avatar
Not 1939 pickup.
V12Bill is offline   Reply With Quote
Old 09-18-2014, 12:23 PM   #16
G.M.
I agree, it looks like it's from a P/U. G.M.
www.fordcollector.com
Old 09-18-2014, 04:53 PM   #17
The Brassworks
The Brassworks's Avatar
The top tank is a 1935 Ford car April to December production. The sidewalls are missing the "backward 7" hood latch and the upper tabs. It is also missing the overflow which comes out of the top tank from a small cup and runs down the front center. The Brassworks has photos of reproductions and restorations on the website.
The Brassworks is offline   Reply With Quote
Old 09-18-2014, 07:13 PM   #18
JM 35 Sedan
Thank you all for your input on this. It looks like fordscript was the first to get it right, others thought the same as fordscript, and then The Brassworks came with the final confirmation that this is indeed a late, small top tank, '35 passenger car radiator with all those items mentioned changed from the original design.
BTW, if I were in the market for a new repro radiator for my '35, I would order it from Brassworks. All the other radiator manufacturers, that I am aware of, cater to the street rod market instead of trying to make their products fit an original vehicle.
John
