Old 07-02-2014, 07:36 PM   #1
J Franklin
J Franklin's Avatar
Default Re: Height adjustment
You could reverse a few of the spring leaves, or if the spring is sagging too much have it re-arched.
Old 07-02-2014, 07:45 PM   #2
bradtripp
would that account for it being low on just one side?
bradtripp is offline   Reply With Quote
Old 07-02-2014, 07:46 PM   #3
bradtripp
Or should I say Could that account?
Old 07-02-2014, 07:54 PM   #4
goodoldvic
goodoldvic's Avatar
Hi try loosing the spring u bolts thru the frame and pushing up on the low side, with some force then retighten the u bolts. they lean like that sometimes cause only one rider has been in it.
goodoldvic is offline   Reply With Quote
Old 07-02-2014, 08:03 PM   #5
goodoldvic
goodoldvic's Avatar
Push up on the body, on the door header that's what I've done in the past. You could pull the springs( use proper tool on rear) and re arc them. I did my front and it cured the lean, for a while anyhow
