Height adjustment Hi everyone, I just logged onto this forum for the first time. I have been building and restoring VW's for a long time and just purchased a 31 Model a pickup the other day. I totally dig it. I notice that it is not sitting square to the ground.. Drivers side setting almost an inch lower to the ground than the passenger. I was wondering if someone in this group of fellow enthusiasts has any insight as to a remedy to fix this problem. Any help would be appreciated.............Brad
Re: Height adjustment The height is different from the ground to the frame
Re: Height adjustment You could reverse a few of the spring leaves, or if the spring is sagging too much have it re-arched.
Re: Height adjustment Quote:
Re: Height adjustment Hi try loosing the spring u bolts thru the frame and pushing up on the low side, with some force then retighten the u bolts. they lean like that sometimes cause only one rider has been in it.
Re: Height adjustment Push up on the body, on the door header that's what I've done in the past. You could pull the springs( use proper tool on rear) and re arc them. I did my front and it cured the lean, for a while anyhow
Re: Height adjustment The lean is caused by many years with just the driver who might have been a tad portly.
Re: Height adjustment Take your time and study your car. Maybe the spring off center. Look at shackle wear. We have covered this on the Barn many times. Lube the shackles and spray the springs with a light lube. Don't start tearing the car apart right away. Bad idea. Get her running and enjoy her. She will tell you what she need fixing. A one inch sag ain't bad
Re: Height adjustment Take a hefty bud for a ride and see if it evens up
Re: Height adjustment Bradtripp, how far are you from clay county, I have a spring spreader.
Re: Height adjustment Hi Brad,
A. Without "seeing" what you have, "anything" is possible & solution "guesses" could run into the millions from broken spring leaves to old Fatty Arbuckle driving you car for 20 years. B. But you can let us know in detail a few accurate measurements & distances after first driving on to a level paved surface & indicate dimensions from: 1. Ground to bottom of chassis behind left & right front axle; &, 2. Ground to bottom of chassis in front of left & right rear axle; &, 3. Ground to center of the L & R spring's outer round eyes at shackles of the front axle; &, 4. Ground to center of the L & R spring's outer round eyes at shackles of the rear axle. C. Both front & rear springs are designed to be secured with a center bolt in the spring's center which should be provided at the transverse center of the vehicle. D. After seeing what you have, you will quickly realize that everything on a Model A is very straight forward & very simple & can be resolved with just simple thinking. E. After measuring, just for kicks, let us know what you find -- many will try to assist if more help is needed . |
Re: Height adjustment Brad, DON"T think that we're being over cautious about that "spring Spreader"! Those things are capable of severing limbs. and they make short work of a too light spreader made from scrap 3/4" pipe. There's a lot of energy in the spring, especially the rear one. Mine bent a 3/4" bolt like a piece of wet spaghetti.
Terry |
Re: Height adjustment 1. Disconnect the shocks links, (check if any shocks are frozen) if any are frozen, then drive around a couple of blocks (to let things settle in) then recheck, parking in the same spot in driveway as the first measurement.
If one of more shocks are frozen it can hold the car up on one side or hold it down on one side. 2. Also be sure the pavement in your driveway is level. There is one spot in my concrete driveway where the left rear wheel sits that is lower than the rest of the driveway where the other 3 wheels sit ... makes it look like car is leaning to one side. |
Re: Height adjustment First, Park the vehicle on a level surface. Throw down something to lay on and start measuring at different points of the suspension. It starts with the frame. If the frame is tweaked you can always get by with shimming. Check all bushings, shackles, tire & wheel heights. A 1/4" in the suspension or frame can multiply on the outside body measurement.
Re: Height adjustment Well, I left Vermin's R/H door open for 3 days & he leaned to the RIGHT. Left his L/H door open for 3 days & he was level! Left the L/H door open for 3 MORE days & he leaned LEFT!
Does HE have a problem, or do I have a problem??? Buster T. WON'T comment. Bill W. |
