Old 07-01-2014, 10:12 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Spark and Gas Rod Colar
Originally Posted by JOES31 View Post
Tom
Is the part with the notches flat all the way down or is there a bow in it at the lower part. Mine is flat down to about 2/3 the way down then goes back about 3/16 to the bottom. It tends to make the lever snap down. is this the way it is supposed to be. It is fairly substantial so I can't see how or why anyone would have bent it.
Can the bottom of the lever that goes into the notches be sharpened a little.
The notched plates should be flat. Like Gar, I have also purchased new rods and found them to be excellent.
