Old 05-28-2014, 09:43 AM   #5
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Tappet noise ?
The center cam main bearing is known to cause a noise that sounds
like a loose lifter. Did you measure the housing bore and both cams
too see what the clearance is? This should be done every time you
change cams...
d.j. moordigian is offline   Reply With Quote
