Old 05-07-2014, 08:46 AM   #1
tanner
tanner's Avatar
Default Bottle Jack for '49 F1
I am trying to get information on correct bottle jack for my 49 F1. I can see hole in floor beside seat where jack is stored but I'm not sure about what jack I need to be looking for. Read some old posts from a few years back but am still confused. Any help will be much apreciated!!
tanner is offline   Reply With Quote
Old 05-07-2014, 08:51 AM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Bottle Jack for '49 F1
http://www.ford-trucks.com/forums/90...a-picture.html
http://www.ford-trucks.com/forums/12...nd-handle.html
Those may be the threads you were looking at?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-07-2014, 09:02 AM   #3
tanner
tanner's Avatar
I had seen part but not all. Good info, now I need to do more reading.
Thanks for the leads.
Old 05-07-2014, 09:26 AM   #4
1952henry
1952henry's Avatar
Contact Lin Stacey. He probably has the correct jack and handle in stock.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-07-2014, 09:37 AM   #5
Bob C
Here's one that just sold on Epay. http://www.ebay.com/itm/FORD-1948-19...p2047675.l2557
Old 05-07-2014, 11:17 AM   #6
gearhead1952
gearhead1952's Avatar
Originally Posted by Bob C View Post
That is not the correct jack as it does not have the hole for the mounting screw in the corner of the base. That is if correctness is important. If not a late model ford ranger truck jack will also work.
gearhead1952 is offline   Reply With Quote
Old 05-07-2014, 11:49 AM   #7
tanner
tanner's Avatar
I wondered about the missing hole as well. Think I'll look for a Ranger jack to use until I can find /afford the correct one.
Old 05-07-2014, 12:19 PM   #8
1952henry
1952henry's Avatar
If you want correct, again check with Lin Stacey...
http://flatheadtools.net/index.html
Old 05-07-2014, 12:32 PM   #9
Vic Piano
Vic Piano's Avatar
Here are two photos of the jack that came with our '51 F-1, I think it is original, including the "thumb screw" hold down. I would think it should be the same for '48 to '52 F-1's.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-07-2014, 01:44 PM   #10
Ross F-1
Ross F-1's Avatar
Does that have the curved plate on top like the eBay unit? I have to wonder what the purpose of that is.
Old 05-07-2014, 02:04 PM   #11
Vic Piano
Vic Piano's Avatar
Ross, no, I've never seen any thing like the jack on e-bay... Don't have a clue what it was used for... Maybe its for a COE...
Old 05-07-2014, 02:27 PM   #12
Ross F-1
Ross F-1's Avatar
Where does your hand-crank for the jack stow? I've never seen any provision for that.
Old 05-07-2014, 02:55 PM   #13
Bruce Lancaster
The Ebay jack is at least a close relative of several similar types used circa 1935-6...it is a "Flip-Top", with the curved upper forging serving to give a higher cradle for jacking at the rear axle tube and the lower part beneath it offering a lower perch to the front axle.
Old 05-07-2014, 03:04 PM   #14
1952henry
1952henry's Avatar
I believe Vic has the correct jack. It's a smaller version of the jack for the F3s.
Old 05-07-2014, 04:17 PM   #15
tanner
tanner's Avatar
I did get in touch with Lin Stacey and he has been most helpful. I hope to get a correct "flip top" jack and crank from him. I would to have the entire tool kit as well.
Old 05-07-2014, 04:18 PM   #16
Barry-ct
Barry-ct's Avatar
I pulled a jack from a 51 F-2 and it was an original. I then compared it to a 84 Ranger 4x4 I had at the time and it was identical to the original, right down to the hole in the correct spot. Use the Ranger jack, a lot cheaper!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 05-07-2014, 04:26 PM   #17
Ken Crans
Ken Crans's Avatar
Is that the correct location for the jack to stow regarding Vics pics?
Ken Crans is offline   Reply With Quote
Old 05-07-2014, 04:32 PM   #18
39wdy
Hey, I thought that jack looked awful familiar... just went out and looked at the old jack collection (now that the snow has melted and I can get into the shed). I have six of these jacks in my collection and five have the folding handles to go with them. Two are exactly like the pictures of Vic's jack and the other four are the same in regard to the jack body but have a three inch by 1 and 1/4 inch top bracket with 1/2 inch ends bent up at each end. The handles are various lengths but all have a distinctive little hook on the end to firmly hold the handle into the jack body. Who needed one of these? Perhaps I can talk him into needing two? My wife would be happy for me to shrink my collection. Toby Lampert
39wdy is offline   Reply With Quote
Old 05-07-2014, 05:18 PM   #19
Vic Piano
Vic Piano's Avatar
Ken, that is the correct location, its the only place in the floor with the provision for the "thumb screw" to secure the jack.
Old 05-07-2014, 05:21 PM   #20
Vic Piano
Vic Piano's Avatar
I don't now if there is a "proper" place (or way) to stow the hack handle, I just keep it under the seat, or in the optional "tool Tray" that mounts to the cab just above the gas tank.
