Old 04-20-2014, 09:33 AM   #1
Greg liekweg
Default 2 tooth steering ajustment
Is their any adjustment for the 2 tooth steering box. Wheel is tight to shaft, But I have about 3" play before pitman arm moves.
Greg liekweg is offline   Reply With Quote
Old 04-20-2014, 09:56 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: 2 tooth steering ajustment
Yep, 4 of them which have to be performed in order. Its best to get a set of the service bulletins or Les Andrews book.
Old 04-20-2014, 12:55 PM   #3
RonC
RonC's Avatar
Don't touch the slotted rivet adjustment.
RonC is offline   Reply With Quote
Old 04-20-2014, 01:53 PM   #4
Forditude
I just adjusted my 2 tooth box per the Andrews book and it works great. I now have the best steering A I've ever had. Don't worry if you haven't ever done it before. Just follow the procedure and go for it. Jay
Forditude is offline   Reply With Quote
Old 04-20-2014, 04:10 PM   #5
Greg liekweg
Just did it. ALOT better. Thanks
Old 04-20-2014, 04:13 PM   #6
Mitch//pa
while your at it make sure there is no play at the sector to pit man arm
ck it with the wheels on the ground moving the strg back and forth a little
sometimes that bolt needs to be tightened
Old 04-20-2014, 11:23 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Why?
Old 04-21-2014, 05:12 PM   #8
modelaer
modelaer's Avatar
I've never had a problem with the slotted rivet adjuster. If memory serves me right it is for equalizing the lash either side of the center of steering.
Pete
modelaer is offline   Reply With Quote
