#21 | |
![]() Quote:
This is great news.
Jim Cannon Former MAFCA Technical Director ![]() "Spread the Joy! Have a Model A day!" |
#22 |
#23 |
#24 |
Tod,
I am constantly being asked to provide a stronger engine that is ultra reliable and doesn't leak oil yet keeping as close to stock "A" appearance as possible. I rebuild both A & B engines and find that the stock A block is still readily available and cheap (I have over 30 good cores and I find my stock increasing each year.) If you build something close to stock, I would likely not be a steady customer. I think for your endeavor to be the most successful, you need to provide what the "A" and the "B" block do not offer. Respectfully to your efforts and the previous posters on this forum I offer the following comments and opinions: Given the engine build requests I hear, the following is what I could sell for you. A new improved block with "stock" A appearance at first glance and incorporating: 1) Late B crankshaft design (counterweighted) maintaining B size main & rod journals or if A sized main journals, it will need 5-main bearing design. 5 main bearing design will require considerably larger rod bearing diameters as the width will be reduced. 2) Machined for inserts...including the cam bores 3) Provision for full oil filtration...possibly supply from the slotted oil pump plug on the side of the engine...through a remotely mounted oil filter hidden in the frame rail and then return to a somewhat hidden spot to feed the mains....even better...exit and re-enter between the valve chamber and the flywheel housing for a "hidden" remote oil filtration system. 4) Better intake port design ...like the B...able to produce more power...include 1.7" intake valve sizing in the base engine design. 1.5" exhaust is good 5) Correct the thin casting areas in the B block port design that made them so prone to cracking between the ports and cylinders 6) Adaptable rear main seal area to accept the very reliable Chevy 350 rear seal (Chevy...I know... blasphemy!) FWI: Dan McEachern makes an adapter to mount the 350 Chevy rear seal to the B block with minor machining...works great! If you do this...I am on board...I can sell them along with original block re-builds all day long! Thanks for the opportunity to suggest input. Dave Gerold ps: The Terry Burtz engine, if it comes to market, will likely be an option for my requirements for a (short-block) to build my performance engines on. His plan to build a fully pressurized A block, including the rods, yet make it look basically stock will be attractive. Price will probably be the determining factor when it comes down to it and that is (or should be) of concern to both of you. (Supply vs Demand) If you both bring your blocks to market, I am sure I will be purchasing some of each to study and test. I sincerely wish you the best success! www.fordmodelaengines.com or www.durableperformance.net Last edited by Dave in MN; 03-27-2014 at 04:40 PM. |
#25 | |
![]() Quote:
I appreciate your input, and other discussions have basically concluded the same things. I don't see any problem getting you the product you ask for. Tod |
#26 |
http://youtu.be/KMYwpHBElMs Please read my opening comments about the pour. Tod |
#27 |
That was awesome Tod, thanks for the great video!!
1929 Model A Ford Coupe |
#28 | |
![]() Quote:
![]() Can you tell us basically, what difference between your block metal formula and Fords ? Two things come to mind; WHAT CAN BE DONE TO IMPROVE FLOW over fords B design; and 1/4" deck thickness...with your metal , is that ENOUGH to prevent cracking that Ford stock blocks commonly have ? |
#29 |
Can I just say....
The accidental soundtrack is awesome when you take the songs in the context of the video... Starts with "I Still Haven't Found What I'm Looking For" by U2 Goes into "Feels like the First Time" by Foreigner right as they start to pour Then, as you note, "Black Dog" by Zep. Just something this music nerd noted and smirked about. -Tim
No one wants advice - only corroboration. -John Steinbeck |
#30 | |
![]() Quote:
Tod |
#31 | |
![]() Quote:
Great input!!!!!! Exactly what I was thinking. Though I still want an aluminum block!!!! . . |
#32 |
I will only be offering updates and discussion from now on by PMs, the HAMB, and the new email account I have set up for this project, [email protected].
Tod |
#33 | |
![]() Quote:
thanks for the video good luck Last edited by Mitch//pa; 03-28-2014 at 11:06 AM. |
#34 | |
![]() Quote:
Having worked on two block casting and machining projects, a Duesenberg and Packard block in the past, porosity was the biggest problem, but we were finally able to overcome it. |
#35 |
I agree with you Mitch, but in the same token I think it's unfortunate that he has to even go that route and feels that he can't talk about it openly here.
1929 Model A Ford Coupe Last edited by Franchise_24; 03-28-2014 at 08:03 AM. |
#36 |
My thoughts also about the cam bearings, crank and main bearings especially. Too bad this and the Burlington crank production do not overlap time wise. Hoping that afew Burlington cranks are still left on a shelf somewhere when I am able to get back to work on the Delivery Sedan.
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
#37 |
I also agree .its obvious where the problem lies !!! Who could blame Tod, We've seen this happen before, same culprets.
#38 |
Having also been attacked publicly and privately this is a wise move to deal with those that throw stones in a glass house. Rod
#39 | |
![]() Quote:
#40 |
Did I miss something? Where were the attacks? There are three threads going on about this exact same topic. Three different places to go to read about what is happening.
It started on HAMB and he is bringing it back there, I read nothing into it except he only wants to follow one thread. Smart move, easier to keep all informed and harder to miss something. This is a great and needed part for the hobby. WAY TO GO TOD! ![]()
