Old 03-25-2014, 07:51 AM   #1
kelley's restoration
kelley's restoration's Avatar
Default new block cast in OHIO
saw this on the hamb
not sure if it was posted here or not
http://www.jalopyjournal.com/forum/s...d.php?t=616056
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 03-25-2014, 09:00 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: new block cast in OHIO
That is cool, now there will be two suppliers of new blocks! If he beefs the block up to 'B' specs but keeps the outside looking 'A' we will be in heaven as far a new engine goes.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-25-2014, 09:28 AM   #3
Del in NE Ohio
Del in NE Ohio's Avatar
model "t"!
Del in NE Ohio is offline   Reply With Quote
Old 03-25-2014, 09:39 AM   #4
TinCup
TinCup's Avatar
Wow exciting stuff. Maybe the guy doing the 5 main block needs to talk to this guy since he has had so much trouble with the pourings from Lodi.
TinCup is offline   Reply With Quote
Old 03-25-2014, 09:39 AM   #5
Jim/GA
Jim/GA's Avatar
Originally Posted by Del in NE Ohio View Post
model "t"!
Model T head.
Model A block.
His post was a bit confusing because he jumped form one to the other.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 03-25-2014, 09:42 AM   #6
Pinstripe
Wow! A new A block from Snyders. Hopefully it will be available soon.
Pinstripe is offline   Reply With Quote
Old 03-25-2014, 09:46 AM   #7
Jim/GA
Jim/GA's Avatar
He has some really pretty patterns. He has not poured one yet. That's when the fun begins.
Terry Burtz has some really pretty patterns, too. (I have seen them.) This is a complex casting to pour, get the metal to flow where you want it, and get all the air and other gasses that come out of the metal and molds to escape (not leave big voids).
I wish them both luck because I want one!!!
Jim Cannon
Old 03-25-2014, 10:08 AM   #8
P.S.
Interesting to note that this is the same gentleman who makes the high compression Model A heads for Snyder's. If his Model A blocks are as good as his heads, we will be in tall cotton! Very exciting times.
P.S. is offline   Reply With Quote
Old 03-25-2014, 10:26 AM   #9
his post on the second page says he has cast them and is tooling them up now for machining
tk
[email protected]
Old 03-25-2014, 10:41 AM   #10
Jim/GA
Jim/GA's Avatar
tk
I saw that he had cast one. Through the machining process he will see if there are any voids, etc. I hope he has a way to do some non-destructive testing on the first few, too, to confirm they are all sound.
Very exciting. I'm "in" for 1 or 2.
Jim Cannon
Old 03-25-2014, 07:19 PM   #11
Flathead
Flathead's Avatar
Keep it with three mains, maybe Model B size mains at least an option.
Flathead is offline   Reply With Quote
Old 03-25-2014, 09:10 PM   #12
Purdy Swoft
Purdy Swoft's Avatar
Model B size mains would be good. Model B size rods would be even better.
Old 03-25-2014, 10:11 PM   #13
1930artdeco
From reading over on the HAMB, it looks like a finished block ready to be put together will be around 2500-3k.
Mike
1957 Country Sedan
Old 03-26-2014, 08:18 AM   #14
Patrick L.
Patrick L.'s Avatar
Now to find a crankshaft.
Old 03-26-2014, 04:03 PM   #15
Tod
Mike
I hope to keep it where I can make money and still sell a lot of them!
Tod
Tod is offline   Reply With Quote
Old 03-26-2014, 04:12 PM   #16
Tod
It really isn't that tough of a casting. I've made vastly tougher ones than this. My first FE block was good, my 351 Clevelands had some chaplet problems, but once I found a better chaplet than the foundries had on hand the problem was solved. I've been in the casting industry for 37 years, so I better be able to make these!
Tod
Old 03-26-2014, 05:00 PM   #17
Crazydaddyo
Crazydaddyo's Avatar
Here is a picture of the first pour:
Crazydaddyo is offline   Reply With Quote
Old 03-26-2014, 05:10 PM   #18
Patrick L.
Patrick L.'s Avatar
Oh OK, I thought it was going be 5 bearing block.
Old 03-26-2014, 09:07 PM   #19
Dodge
Man, thats a great looking casting. Exciting stuff. Keep up the good work.
Dodge is offline   Reply With Quote
Old 03-26-2014, 10:29 PM   #20
Chris Haynes
Chris Haynes's Avatar
The Terry Burtz engine is the 5 main, counter balanced, full oil pessure engine. Cast in Green Sand so it looks identical to what Henry made.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
