Old 02-19-2014, 04:18 PM   #1
Bill Goddard
Bill Goddard's Avatar
Default Re: The 8th stud
Originally Posted by chl View Post
I know I read somewhere that if the cable isn't secured by the clamp it will cause the connection to eventually fail at the ignition switch from cable being loose. Just wondering if this is true.
I don't beleive it. The cable is held tight in the switch housing it can't move. Failure was probably insulation of the inner wire wearing through if it was original wire. Bill G
Bill Goddard is offline   Reply With Quote
