Old 10-28-2013, 08:06 PM   #7
SETHDOUG
Default Re: Rust In Gas Tank I CAN FEEL YOUR PAIN
Originally Posted by henry cambron View Post
i've got a 1930 model a that i inherited and i wanted to check everything out real good before i tried to start the engine. It belonged to my cousin and a friend told me that he last saw it run a little over a year ago.
Anyway, there is visible flaky rust in the gas tank. I did a search on the forum and have been reading through some old threads. I'm going to use a shop magnet on a stick and get what i can see first and then i thought i would try flushing several times with a rust remover.
I've found references to two particular chemicals and i was wondering if anyone had an opinion as to which would work better: Evapo-rust or esprit from rustdepot.com?
Thanks,,,
many of the model a parts houses sell a ssmall stand pipe that slides right into your gas tank valve . This is a tube with a stainless steel screen on it that allows you to suck gas from a higher point than the valve intake ,, thus the rust settles in the bottom of the tank and good gas flows through the screened tube ,,, pretty cool huh ????
SETHDOUG is offline   Reply With Quote
