Old 12-20-2012, 02:37 PM   #1
my64gal
Question rearseat backrest 29 tudor
how does the backrest attach to the body on a 29 tudor. there are no slots like on the 30 and the clips are attached to the wood frame around the window
my64gal is offline   Reply With Quote
Old 12-20-2012, 08:05 PM   #2
Dal's Dream Car
Dal's Dream Car's Avatar
Default Re: rearseat backrest 29 tudor
You may want to post some pictures of what your dealing with. I just finished the interior of my 29 Tudor and there are 2 tabs on the back of the seat that slide into slots. Two metal tabs on the bottom which need to be lined up and/or drilled then secured with a nut and bolt.
Dal's Dream Car is offline   Reply With Quote
Old 12-21-2012, 12:45 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Here's my 2-23-29 Tudor. Notice that my car is in the transition period and has both the slots and the brackets. My seat back top hooks over the two brackets.
Old 12-21-2012, 06:19 PM   #4
my64gal
mine is a may of 29. I have the clips like yours and no slots
Old 02-06-2019, 09:20 PM   #5
father-son
Weird, so ours is a Nov 29 Tudor. We have brackets mounted to the wood seat frame but no slots. Needless to say, lots of head scratching to figure it out but this site saved our bacon. Thx!
father-son is offline   Reply With Quote
Old 12-22-2012, 01:25 PM   #6
Steve Plucker
My Seattle assembled Tudor, A Feb. 29 also, has the same set up as yours does Tom.
Pluck
Old 12-21-2012, 07:32 AM   #7
Great Lakes Greg
Great Lakes Greg's Avatar
That's interesting, Tom. My 3-6-29 had the brackets and may have had the slots, but I wasn't paying attention when it was apart. I assume the slots eventually replaced the brackets?
Great Lakes Greg is offline   Reply With Quote
Old 12-21-2012, 10:57 AM   #8
Marco Tahtaras
Marco Tahtaras's Avatar
The rear backrest spring and frame assembly is different for your car. It only used a partial wood frame with no wood across the top. I'm thinking this pic was from Tom.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-21-2012, 06:21 PM   #9
my64gal
the wood frame you have is what mine looks like. with the responses here i can see what i need to do. thanks to all
Old 12-21-2012, 05:54 PM   #10
Dal's Dream Car
My 29 did not have those brackets on the wood. Just the slots in the steel. I never had the original backrest and got everything from Lebaron Bonney. It fell in quite nicely. The bottom two brackets took a fair amount of head scratching to line up and drill..
Old 12-21-2012, 07:13 PM   #11
Tom Wesenberg
Here is the passenger side bracket for the bottom of the back rest. Notice that it still has the bolt and a piece of the wire frame that broke off the rear backrest spring. In the picture Marco posted above you can see the two wire loops at the bottom of the backrest used to secure the bottom.
The dark area is where I squirted some oil to start the bolts soaking for later removal.
