Old 01-16-2012, 09:37 PM   #1
badbones
Default Rear brake track rivet
I'm going to replace both heavy worn rear tracks on my 29 Tudor. It seems simple enough to grind off the old rivets but have two questions.
I plan on buying the new track from snyders unless there are better ones out there.
I know I have to red hot the new rivets but What technique to get the mushroom head? Is there a special tool or just smack it to flatten it out?
Thanks
badbones is offline   Reply With Quote
Old 01-16-2012, 09:59 PM   #2
CA Victoria
CA Victoria's Avatar
Default Re: Rear brake track rivet
I used an old punch. I ground the end flat and then used a large drill bit and drill press to create a counter sink in the end. Not just like Henry's, but worked well.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-16-2012, 10:12 PM   #3
Fred K-OR
Fred K-OR's Avatar
I used a "ball pein" hammer. Takes a little work but you can get them round like they need to be.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-16-2012, 10:34 PM   #4
Jim Parker Toronto
Jim Parker Toronto's Avatar
Heated bright red, then air hammered down with concave bit.
Jim Parker Toronto is offline   Reply With Quote
Old 01-16-2012, 11:28 PM   #5
badbones
Jim
I like your idea there. Is this what your talking about?
http://www.amazon.com/K-Tool-Interna...6774366&sr=1-2
Old 01-17-2012, 06:12 AM   #6
Tim B.
Drilled center of heads out with a drill press and finished with a punch. Installed like Jim did. Right tool on link wrong size I ended up using a 3/16 inch and worked fine. Rivet end is 1/4" but found not enough material to fill the tool cavity of a 1/4" tool & draw rivet tight. Had to Finish with a ball peen hammer. Get a beehive spring from NAPA or other auto house for your air gun to hold the tool. If you're not in a hurry check aircraft tool houses online for tool & Spring less expensive since they're not specialty tools for them. Tim
Tim B. is offline   Reply With Quote
Old 01-17-2012, 08:49 AM   #7
Aerocraft
Aerocraft's Avatar
For others that need this work done, it is very likely that someone in your local car club, especially an aircraft mechanic, has the equipment that you need. It is rather expensive to buy the gun and set just for four rivits. The rivits do need to be driven while the shank of the rivet is red hot.
It has been my experience that some of the aftermarket parts do not fix perfectly so pay close attention to the fit of the parts before you drive the rivits.
If you are close to the Chicago area, bring them to my shop and I'll install them for free but it does take two people. I do expect that the owner will help.
Gar Williams
Aerocraft is offline   Reply With Quote
Old 01-17-2012, 09:05 AM   #8
JBR
JBR's Avatar
How about these:
http://www.snydersantiqueauto.com/2423 or
http://www.snydersantiqueauto.com/2422
JBR is offline   Reply With Quote
