The Ford Barn
-   -   Rear brake track rivet (https://www.fordbarn.com/forum/showthread.php?t=59221)
badbones 01-16-2012 09:37 PM
I'm going to replace both heavy worn rear tracks on my 29 Tudor. It seems simple enough to grind off the old rivets but have two questions.
I plan on buying the new track from snyders unless there are better ones out there.
I know I have to red hot the new rivets but What technique to get the mushroom head? Is there a special tool or just smack it to flatten it out?
Thanks
CA Victoria 01-16-2012 09:59 PM
Re: Rear brake track rivet
I used an old punch. I ground the end flat and then used a large drill bit and drill press to create a counter sink in the end. Not just like Henry's, but worked well.
Fred K-OR 01-16-2012 10:12 PM
I used a "ball pein" hammer. Takes a little work but you can get them round like they need to be.
Jim Parker Toronto 01-16-2012 10:34 PM
Heated bright red, then air hammered down with concave bit.
badbones 01-16-2012 11:28 PM
Jim
I like your idea there. Is this what your talking about?
http://www.amazon.com/K-Tool-Interna...6774366&sr=1-2
Tim B. 01-17-2012 06:12 AM
Drilled center of heads out with a drill press and finished with a punch. Installed like Jim did. Right tool on link wrong size I ended up using a 3/16 inch and worked fine. Rivet end is 1/4" but found not enough material to fill the tool cavity of a 1/4" tool & draw rivet tight. Had to Finish with a ball peen hammer. Get a beehive spring from NAPA or other auto house for your air gun to hold the tool. If you're not in a hurry check aircraft tool houses online for tool & Spring less expensive since they're not specialty tools for them. Tim
Aerocraft 01-17-2012 08:49 AM
For others that need this work done, it is very likely that someone in your local car club, especially an aircraft mechanic, has the equipment that you need. It is rather expensive to buy the gun and set just for four rivits. The rivits do need to be driven while the shank of the rivet is red hot.
It has been my experience that some of the aftermarket parts do not fix perfectly so pay close attention to the fit of the parts before you drive the rivits.
If you are close to the Chicago area, bring them to my shop and I'll install them for free but it does take two people. I do expect that the owner will help.
Gar Williams
JBR 01-17-2012 09:05 AM
How about these:
http://www.snydersantiqueauto.com/2423 or
http://www.snydersantiqueauto.com/2422
