Old 12-13-2011, 10:26 AM   #1
carguy01
Unhappy button style rotor cap
Good morning I have a question about the button style rotor cap on my 55 ford 272 y block. it seems to have a lot of play on the shaft. The rotor is brand new and it comes from Mexico Is there a ford part no. someone can give me or can someone suggest where i can get a better fitting one?
carguy01 is offline   Reply With Quote
Old 12-13-2011, 11:29 AM   #2
1942deluxe
1942deluxe's Avatar
Default Re: button style rotor cap
FAA 12200 B is the Ford number.DR 1 is the Motorcraft number.Your local Ford dealer should be able to get it for you.If not call me I have them in stock.
John Kelley
B&L Ford
Ashland,Pa.
570-875-4417
1942deluxe is online now   Reply With Quote
Old 12-13-2011, 11:46 AM   #3
carguy01
thank you sir.
Old 12-13-2011, 03:53 PM   #4
darrell
these early dist,have a clip on the shaft that keeps the rotor tight.is yours there.
darrell is offline   Reply With Quote
Old 12-13-2011, 04:18 PM   #5
Ole Don
Ole Don's Avatar
Darrell is right, look inside the old rotor to see if the clip is stuck in it. Dont spend a lot of money on that distributor, the 57 and newer is much better. NAPA has them.
Ole Don is offline   Reply With Quote
Old 12-13-2011, 07:49 PM   #6
carguy01
The clip is there . How much is a new distributor from napa? thanks everyone carguy01
Old 12-14-2011, 07:36 AM   #7
darrell
for everyday driving i never had a problem with the early dist,.if you have a 55 carb you cant hook your vacuum advance to it with a 57 dist,.
