Old 05-08-2026, 03:22 PM   #1
flathead4rd
flathead4rd's Avatar
Default Heater blower motor control switch removal tool.
The bezel on my 50 for the blower motor control switch appears to need a special tool to unscrew it. Has two holes 180 degrees apart. The knob and shaft can be removed for access. Any suggestions?
flathead4rd is offline   Reply With Quote
Old 05-08-2026, 07:08 PM   #2
mcgarrett
Default Re: Heater blower motor control switch removal tool.
Here ya go!
https://shoebox-central.com/1949-195...l-removal-tool
Old 05-08-2026, 07:29 PM   #3
tubman
tubman's Avatar
I was in a hurry, so I made one by using an appropriately sized 1/4" drive deep socket and grinding it back to make the "teeth" needed to grab the nut. Interestingly, a few year later I needed a similar tool to remove one of the dash nuts on my Corvette; I remembered the one I had made, found it in my toolbox, and it worked for that as well.
Old 05-08-2026, 08:47 PM   #4
mcgarrett
I did the same thing several years ago. Since this is America, I sacrificed a metric deep socket!
Old 05-09-2026, 08:02 AM   #5
Tom F OHIO
Tom F OHIO's Avatar
Good job mcgarrett for finding the tool for this guy.
Tom F OHIO is offline   Reply With Quote
