#121 |
The key appears to be from the 8BA era.
#122 |
Tubman, I thought that too. It's an Ilco 1125K key. I have seen those blanks used as a replacement for the earlier cars.
#123 |
I have seen that type of lock on closed cars too. I'm not sure why you would want to lock the spare tire that is locked in your trunk, but I have seen it.
#124 |
Folks,
John is the proud owner of another engine. I posted under the 46 thread but he many have many other options for it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() John will fill you in on the details. I believe it rolls over. Good news. Regards, Chris and Cheryl
1932 AAB Truck 1953 Ford Jubilee 1965 Mercury Comet Caliente 1966 Ford F100 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
#125 |
Wow, that is a clever adaptation to use an 8BA generator on an earlier engine.
#126 |
#127 |
This vacuum plate spacer was under the 8BA carburetor that came with the engine. It has the normal 59 A-B intake with the silencer so it wouldn't be needed. Anyone have any idea what it came from? I know I've seen them before. |
#128 | |
#129 |
Those are installed to allow for an aftermarket vacuum accessory, typically a South Wind gasoline heater.
