Old 07-25-2025, 08:34 PM   #4
mcgarrett
Default Re: how to keep windshield open
Originally Posted by Jim/GA View Post
On open cars, remove the two stanchion wingnuts at the top of the windshield (only do one side at a time) and add 2 flat washers on there, then put the wingnuts back on snug when you have the windshield open to the position where you want it. Add the 2 washers to both sides. The windshield will stay there.
The stud bottoms out inside the wingnut before it is clamped tight to the stanchion.
I have seen people put wooden blocks, tennis balls, pool noodles, all kinds of stuff in the bottom of the windshield because they did not know about the washers.
Thank you Jim C. for the tip to use washers behind the wing nuts. I wasn't having much luck keeping my Roadster windshield set where I wanted it. Your trick worked!
