Old 06-16-2025, 08:00 AM   #1
hueyhoolihan
Default oil pressure gauge extender pipe
i will be needing to tighten the oil pressure sender that sits in a particularly inaccessible location at the back of the engine and was wondering if anyone has installed an extender pipe?
i was thinking that maybe something like this (assuming the threads fit) might help.
https://www.amazon.com/Scott-Drake-C...A30R5LHHY8D2ZM
hueyhoolihan is offline   Reply With Quote
Old 06-16-2025, 08:39 AM   #2
TomC750
TomC750's Avatar
Default Re: oil pressure gauge extender pipe
I managed to install a 6"? nipple in order to get the gauge out further. At first it looked near impossible, but it worked out. This was on my '41 Mercury. The threads are 1/4" pipe.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 06-16-2025, 08:50 AM   #3
hueyhoolihan
thanks tom,
so does your solution pretty much mimic the one pictured in my link? again, assuming the male and female threads would be 1/4" pipe?
for i can probably screw down the sender that's on my car by hand and get it to stop leaking, but getting it off again, sometime in the future, could be problematical. so am looking for something that i can easily reach with a common wrench.
Old 06-16-2025, 09:16 AM   #4
ford38v8
ford38v8's Avatar
Huey, Torch a 90 degree bend to the business end of an open end wrench.
Alan
Old 06-16-2025, 10:57 AM   #5
flathead4rd
flathead4rd's Avatar
What about a Crow Foot wrench? Would that work?
flathead4rd is offline   Reply With Quote
Old 06-16-2025, 01:49 PM   #6
hueyhoolihan
yes, it might.
Old 06-16-2025, 02:34 PM   #7
Bob C
This is a Snap-On wrench I have that clamps onto the sending unit.
Old 06-16-2025, 03:02 PM   #8
petehoovie
petehoovie's Avatar
Old 06-16-2025, 07:09 PM   #9
19Fordy
19Fordy's Avatar
You don't have to buy a special pipe like the one advertised.
Just go to Home Depot and buy a short piece of 1/8-27NPT brass pipe.
Solder or braze a nut around it's circumference for installation.
Old 06-16-2025, 07:59 PM   #10
TomC750
TomC750's Avatar
Fordy is correct. Just extend the horizontal port, and I remembered wrong on the pipe size, as Fordy says it is 1/8".
TomC750
1930 1 Ton White
Old 06-16-2025, 08:01 PM   #11
TomC750
TomC750's Avatar
Fordy is correct. Just extend the horizontal port, and I remembered wrong on the pipe size, as Fordy says it is 1/8". I did not bother to braze a nut, just used a 9/16 open end wrench on the gauge.
TomC750
1930 1 Ton White
Old 06-17-2025, 09:16 AM   #12
Kube
Super Moderator
Kube's Avatar
Bob, I never knew this wrench existed. Cool!
I made one very similar to his from an old wrench I had. No clamp for the unit but have not found that necessary. As Alan had suggested in an earlier post, a little heat, a little bending and my wrench was born
Old 06-17-2025, 03:15 PM   #13
Brian
Brian's Avatar
It is NOT 1/8 it is 1/4 NPT
Brian is online now   Reply With Quote
Old 06-17-2025, 07:53 PM   #14
TomC750
TomC750's Avatar
Hmmm, I was right in the first place! A quick look under the hood would have quantified it.
TomC750
1930 1 Ton White
Old 06-17-2025, 08:29 PM   #15
19Fordy
19Fordy's Avatar
Sorry for the misinformation. I think I used a reducer to make the 1/8-27 fit.
Here's my set up.
Old 06-17-2025, 08:33 PM   #16
petehoovie
petehoovie's Avatar
Here's my set up.
Old 06-17-2025, 08:35 PM   #17
19Fordy
19Fordy's Avatar
Thanks Pete.
Old 06-17-2025, 11:54 PM   #18
cas3
I would be afraid of low quality hardware store chinese nipples. they are thin and could crack in the threads. Go to a hydraulic supply store and get quality fittings made for high pressure.
Old 06-18-2025, 08:05 PM   #19
TomC750
TomC750's Avatar
I suppose it is reasonable to assume Chinese fitting quality has improved over the years, but I remember having some that were totally unusable.
TomC750
1930 1 Ton White
Old 06-23-2025, 09:01 PM   #20
hueyhoolihan
i ended up buying this one...
https://www.ebay.com/itm/187124245529
it came in today and was soon fitted. works well. it's allowed me to fix the nasty oil leak and live without fear of having to replace it at some future date.
