Old 06-07-2025, 10:08 AM   #21
ford38v8
ford38v8's Avatar
Default Re: Ted’s brake floaters
Aftermarket Ford brake floaters have been around since before most of us have been on this earth. The success or failure of these time honored products is always dependent on the correct installation of all components. No indictment of those who've not had success, we all learn from our mistakes.
Alan
Old 06-12-2025, 11:16 PM   #22
FlatheadTed
FlatheadTed's Avatar
If your drums and shoes are worn you can get this issue ,pack up the slots in the top end of the shoe adjuster links with a rivet or a one inch length of 4 " nail ,bend the end to right angle , Or fit 1/4 "linnings .
Originally Posted by azlkk View Post
Just installed them on our ‘35 coupe. No problems with the fronts but the rears couldn’t adjust. Screwed in the adjusters until the end caps got pushed out without getting close to locking the wheels. Has anybody had this issue? I’m back to the OEM adjusters now for the rear.
OLD Ford
Unless they have improved them a lot in the last 15 years, I was not impressed with the kit.
I don't see any Emails from you regarding your comment,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-13-2025, 12:33 PM   #23
azlkk
azlkk's Avatar
I'll give that a try. Linings on the rears look to be about half worn based on the rivet recesses. Drums are 12.00" ID all around so it's likely not that as the fronts with new linings Adjusted nicely.
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new
azlkk is offline   Reply With Quote
