Old 05-31-2025, 08:27 AM   #1
Mart
Mart's Avatar
Default IDing 40s steels. 4" or 4-1/2" wide? Easy how to.
Here's an easy way to tell if your 40s steel is a 4" or 4-1/2".
If you lay a straight edge across the centre of the wheel and up against the outer rim, On the 4" wheel the end will sit just outside the rim. On the 4-1/2" wheel the end will sit just inside the edge of the rim.
4" wheel:
4-1/2" wheel:
A handy little tip especially when the tyres are still on!
Mart.
Old 05-31-2025, 11:41 AM   #2
alchemy
alchemy's Avatar
Default Re: IDing 40s steels. 4" or 4-1/2" wide? Easy how to.
Thanks
alchemy is offline   Reply With Quote
Old 05-31-2025, 02:15 PM   #3
ford38v8
ford38v8's Avatar
Leave it to Mart to come up with easy shortcuts. Good find!
Alan
Old 05-31-2025, 03:42 PM   #4
TJ
TJ's Avatar
I just carry a small tape measure on my key ring. Mart's idea is good but not all wheels have the same back spacing.
Old 05-31-2025, 04:54 PM   #5
big deuce
big deuce's Avatar
Now we just need a " magic" eye ball to see through the tires to inspect the beads while at the bone yard!
big deuce is offline   Reply With Quote
Old 06-06-2025, 11:25 PM   #6
Death Row Dave
Death Row Dave's Avatar
Thanks my friend
Death Row Dave is offline   Reply With Quote
Old 06-07-2025, 09:56 AM   #7
GB SISSON
GB SISSON's Avatar
Mart, I like the way you figure things out. Your next assignment is to make a small, portable gauge to tell if a swapmeet crank is 3 3/4" or 4" stroke. I've found exceptions to the clean out hole sizing ID.
Old 06-07-2025, 11:28 AM   #8
Ken/Alabama
Ken/Alabama's Avatar
I measure across the large counter weight.
Ken/Alabama is online now   Reply With Quote
Old 06-07-2025, 01:49 PM   #9
Flathead Fever
Flathead Fever's Avatar
It seems like any 16" rim would measure the same distance. That makes it look like there are two different diameter rims. I wouldn't want to put a 16" tire on a 15-inch rim.
Old 06-07-2025, 04:41 PM   #10
Mart
Mart's Avatar
You're missing the point.
I'm not measuring any diameters. I'm showing the relative alignments of the rims against the centres. The 4-1/2" wheel is 1/2" wider, so sticks out 1/4" more than the 4". You can see the difference using a straight edge.
