Old 05-29-2025, 05:52 AM   #15
nkaminar
nkaminar's Avatar
Default Re: Mitchell over drive questions
Here is what RYMAX says about their G5 and G4 gear oils: https://rymax-lubricants.com/updates...-gl-4-and-gl-5.
I started using G4 in my Mitchell overdrive and synchro transmission when I found small brass colored flakes in the oil I drained out during the annual change. Your choice. But for my money I will play it safe.
I buy the G4 at the local auto parts dealer. If you cannot find it there then buy it online.
I use the G5 in my differential and steering box.
One more thing: Modern gear oils are much improved over what was available in 1930. I have used 85W-140 G5 in the standard Model A gearbox and it shifts fine as long as I shift slowly or double clutch going up and double clutch going down.
