Old 05-05-2025, 08:51 PM   #1
Boxhead
Default 1941 Semi Truck
Hi All,
Thought I might share a few pics of the newly acquired 1941 semi trailer.
Cheers
C
Sent from my SM-F936B using Tapatalk
Boxhead is offline   Reply With Quote
Old 05-05-2025, 09:19 PM   #2
1952henry
1952henry's Avatar
Default Re: 1941 Semi Truck
That is awesome!
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-05-2025, 10:46 PM   #3
Newc
Newc's Avatar
95 or 85 hp both engs were available V8. Badge on hood may tell. Newc
Old 05-05-2025, 11:19 PM   #4
cas3
Wow!!! that is really cool, looks fresh out of the army in ww2. please tell us the story
cas3 is online now   Reply With Quote
Old 05-06-2025, 12:01 AM   #5
expavr
expavr's Avatar
That is a well preserved truck. Very nice! The hood and hood latch look to be the same as that on my 40 Tonner. What is the device with the lever on the right side of the steering column?
expavr is offline   Reply With Quote
Old 05-06-2025, 04:27 AM   #6
Ggmac
Fantastic! More pictures and information please .
Gary
Old 05-06-2025, 06:26 AM   #7
Rice
I really like that. Cool
Rice is offline   Reply With Quote
Old 05-06-2025, 06:47 AM   #8
GB SISSON
GB SISSON's Avatar
An incredible survivor! It had to have been stored indoors all this time. I don't even see any cracks in the steering wheel! Looks like you have a few more very heavy items in the background that might someday beg to be restored. I too am drawn to the big and heavy but you must keep in mind a strange quirk of nature, or is it science? These big vehicles and equipment seem to attract stray atoms or molecules of iron from thin air which then bond to the components, rendering them ever heavier as time goes by. I recently went to toss a tire/wheel combo onto my flatbed and found it had gained perhaps as much as 30 lbs, so finally gave up and cranked up my old friend the skidsteer for some assistance. Keep up the incredible work you are doing there!
Old 05-06-2025, 07:11 AM   #9
corvette8n
corvette8n's Avatar
Wow that’s awesome can’t wait to see your plans for it.
Old 05-06-2025, 07:13 AM   #10
Jack E/NJ
Jack E/NJ's Avatar
Fuel pump?
Old 05-06-2025, 08:11 AM   #11
leon bee
I had also admired the fuel setup. Beautiful rig!
leon bee is offline   Reply With Quote
Old 05-06-2025, 08:18 AM   #12
40Bud23
Wow...the history it could tell.
40Bud23 is offline   Reply With Quote
Old 05-06-2025, 08:20 AM   #13
51504bat
51504bat's Avatar
Front fenders have a Dodge Power Wagon look to them.
51504bat is online now   Reply With Quote
Old 05-06-2025, 10:34 AM   #14
Bob C
Control for trailer brakes??
Old 05-06-2025, 02:25 PM   #15
sidevalve8ba
sidevalve8ba's Avatar
Am I the only one not seeing the pictures?
sidevalve8ba is offline   Reply With Quote
Old 05-06-2025, 02:38 PM   #16
Seth Swoboda
Seth Swoboda's Avatar
Cool. Tell us more. Engine, transmission, brakes, what is your intended use?
Old 05-06-2025, 08:10 PM   #17
TomC750
TomC750's Avatar
Trailer might be a Kingham. A pic of the landing gear may tell the story.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 05-07-2025, 04:29 AM   #18
Boxhead
Hi All,
So i believe the truck was from WW2, after the war it was in central NSW in Australia and delivered general items as per the ad and an old picture( see pictures).
I bought it from a gentleman's estate that sadly passed, I knew him as he originally sold me the donor truck for the 42 ford Tow Truck I have been restoring. He had no phone no internet so I was in the middle of writing him a letter regarding purchasing the truck but he passed before i was able to send it.
As for the funnel in the picture, I did this so I did not have to rely on the fuel pump and also I did not want to use the fuel tank as I was not sure if the tank was clean.
The lever on the right side of the steering wheel is for the vacuum trailer brakes so you could operate from the cab, this is connected to a vacuum cylinder on the fire wall then off to the trailer which has a vacuum tank above the back axle. ( see picture of tank behind the rear spare tyre)
Cheers
Corey
Old 05-07-2025, 04:43 AM   #19
Boxhead
For me i will not be fully restoring as I do not want to change the truck but rather keep the history.
I will check all the brakes etc and make sure everything functions as it should. I will give it a very good clean and either matt clear it or maybe a boiled linseed mix wipe ( everyone's thoughts?)
They truck starts and idles perfectly now after I rebuilt and cleaned the carburetor, i have flushed the fuel tank and lines and the brake master cylinder needs replacing.
The truck has a 4 speed box and a split differential, it has an early V8 flathead ( i have not looked at any numbers as yet but it has the helmet style distributor)
I also have acquired an early war generator that they used to take to airfields to power the search lights.
Cheers
C
Old 05-07-2025, 05:07 AM   #20
Mart
Mart's Avatar
Wonderful pieces of machinery. Boiled linseed oil is very good. That rig appears to have earnt it's keep back in the day. I really like seeing things like this.
Mart is online now   Reply With Quote
