#38 |
The measurements between the cowl and the rear door shuts on the Phation are the the same as usa ones ,the front doors are also the same in length .The rear doors are a 1" shorter in length, the center pillar is wider and takes up that 1",The doors are shorter in hight to make up for the sill and pie cut angle that Mercman alluded to .The C pillar support is a casting as opposed to a stamping .
