Old 02-26-2025, 05:01 PM   #1
Mike1291
Mike1291's Avatar
Default Rear Hood Hinge - Threads Stripped
Is there a recommendation on how I could reinstall my rear hood hinge? The threads for the bolts no longer hold the bolts in.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 02-26-2025, 05:58 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Rear Hood Hinge - Threads Stripped
I think that there are captive nuts underneath. Unfortunately you have to take the tank out to get to them. One suggestion I have just off the top of my head is to fill the holes with a strong epoxy like JB Weld and then drill and tap for the bolts.
Old 02-26-2025, 06:01 PM   #3
Ray in La Mesa
The caged nuts are pretty inaccessible but you might try drilling out the nuts to the next larger size and JB Welding new nuts to the original nut cages . Would be A LOT EASIER if the tank was out!
Ray in La Mesa is offline   Reply With Quote
Old 02-26-2025, 06:46 PM   #4
Cape Codder
Cape Codder's Avatar
I think that this kit would solve your problem as seen on Snyders web site.
Retainer Cage Nut Kit
A-16735-BMK Model Year 30-31
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 02-26-2025, 07:10 PM   #5
180 a
use a longer bolt and put a nut on the bottom
180 a is offline   Reply With Quote
Old 02-26-2025, 07:41 PM   #6
Keith True
Keith True's Avatar
That's the common fix I've seen.I have a car fixed like that.Spin the longer screw down through,and reach up underneath and screw the nut on.The side pressure from the stripped out nut should hold the screw tight enough to turn the nut on finger tight.If not have somebody else hold it,or set a magnet on the screw heads.I generally don't take that piece off to remove the hood.I pop the hood stay rods off the radiator,and rock it ahead 3/4 of an inch.
Old 02-26-2025, 08:09 PM   #7
Big hammer
Drill and tap to the next size screw, you may have to alter the new screw head to fit hinge
get a bigger hammer tap done
Old 02-26-2025, 09:35 PM   #8
Ayers1
Ayers1's Avatar
That's what I did on mine. I used a socket with an extension and tightened the nut while my wife held the screw on top. Really wasn't hard, just took 2 people.
Ayers1 is offline   Reply With Quote
Old 02-27-2025, 10:57 AM   #9
Richard Knight
I took a short piece of flat stock, measured off the CtoC distance of the two holes, drilled and tapped it for the mounting screws, mixed up some jb weld, applied it to the bar stock and stuck it up under the cowl, put the screws in until the jb weld cured and then I could install the hood and bracket. Might be easier than putting two nuts up under the cowl?
Richard Knight is offline   Reply With Quote
Old 02-27-2025, 11:23 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
These slides should help you.
Bob Bidonde
Old 02-27-2025, 11:35 AM   #11
katy
katy's Avatar
That's what i would do.
Old 02-27-2025, 12:42 PM   #12
ModelA29
ModelA29's Avatar
Could you drill from the top and use a nutsert? would it be hidden?
https://www.amazon.com/GIANTISAN-16-...72094148&psc=1
ModelA29 is offline   Reply With Quote
Old 02-27-2025, 12:50 PM   #13
Y-Blockhead
Y-Blockhead's Avatar
Nutserts (or Rivet Nuts as we call them around here) are an excellent suggestion. You can get a set for only the size you need instead of buying the whole set if you're cheap...
Old 02-27-2025, 04:04 PM   #14
JayJay
On my '31 I originally thought those were stripped out as well. Then I realized that the doofus who "restored" the car had installed screws with a 10-24 thread and nuts instead of the 12-24 that they actually are. A bit of futzing around and chasing the threads in those captive nuts and voila, works as it should!
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 02-28-2025, 09:13 AM   #15
Mike1291
Mike1291's Avatar
The rivet nut tool looks interesting. I'm going to see if I can do a less invasive approach (perhaps the longer bolt) and go from there
Old 03-10-2025, 07:37 PM   #16
Mike1291
Mike1291's Avatar
I took a look at what I have and there's no room for me to add a nut or the repair kit they sell without taking the gas tank out; the tank comes out too far for me to have any room.
If I were to use the rivet nut, should I put the hinge first and rivet nut that? If I add the rivet nut first, I don't believe the hinge will sit flat.
Old 03-11-2025, 08:01 AM   #17
Big hammer
Originally Posted by jayjay View Post
on my '31 i originally thought those were stripped out as well. Then i realized that the doofus who "restored" the car had installed screws with a 10-24 thread and nuts instead of the 12-24 that they actually are. A bit of futzing around and chasing the threads in those captive nuts and voila, works as it should!
x-2
Old 06-08-2025, 08:00 PM   #18
Mike1291
Mike1291's Avatar
Don't listen to what I was saying up there. I didn't understand what people were talking about at first but realized that I had to crawl into the cabin and go behind the gas tank. I found that the captive nuts had freed themselves. I ended up cutting out the old bracket and adding nuts and lock washers where the screws go in. Thanks for your suggestions, though!
Old 06-09-2025, 06:55 AM   #19
Bob Bidonde
This may help you.
Bob Bidonde
Old 06-09-2025, 08:53 AM   #20
old31
So, does anyone see why the rivetnut/nutserts would not work?
old31 is offline   Reply With Quote
