Hi,
I have a question about the part below. How do you mount this? Just make a hole in the hose and tighten it tightly? Is there no need for anything in between, no sealant or glue or anything like that? Looking forward to hearing from you, thanks in advance. |
I have not needed sealer when using one of these on an original type lower radiator hose. I did have to use sealer when installing one in a silicone lower radiator hose (used silicone on a 38 because of how hard it is to get the factory lower hoses on, not a problem on a 41).
Yes, thats it, just tighten it up. While thats how Ford did it, I drilled a hole in the water pump like this...
Never installed one but IIRC this is what some use
Super Moderator
This stuff has been around for decades and there's a reason for that... IT WORKS. I use this on each and every water hose connection I install.
About $3 at your local NAPA store.
I thoroughly cleaned the area where the nipple exits the hose inside and outside with lacquer thinner and applied a liberal coating of 3M Black weather strip adhesive on both sides of the hose and nipple clamps. Allowed the adhesive to become slightly "tacky" and clamped it all together. Happy to report it is holding well with no leaks.
Thank you for all the anwsers.
I use a hole punch to make a perfectly round hole that the adapter just goes through, easily done off the car on the bench with a piece of wood inside. Never had a leak. Make sure you mark on the hose to get the angle you want before making the hole.
Super Moderator
Perfect advice!
