Can anyone recommend a 239 flathead pilot and seat cutter? I've heard new way is good? Just planning on a valve job using the old seats.
Thanks!
52 Ford Customline Fordor |
I have the new way cutters, they are very nice and easy to use, do a great job .
I have a special pilot the engages with the valve guide bore as well as the lifter bore. Lawrie |
I have the same system as Lawrie. They are Neway.
#4 | |
![]() Quote:
Is the "special pilot" a Neway product or something special from another source? I have been looking at these for a while. Denny |
Hey Lawrie, was curious of the diameter of the pilot you have? I have both a Sioux and a Kwikway pilot (for their standard seat holders) - was wondering if they would work with the Neway stuff?
FWIW, I used: CU616 30/45deg valve seat cutter Pilot tool PEM150-8.5mm Wrench TW505. Last edited by fortyonerag; 01-16-2025 at 02:47 AM. |
The pilot I have is not Neway and works just fine. Same one I used when I used to use stones. Sioux
What are you guys seeing as far as the quality of the seat finish and concentricity? Anybody use a seat mic afterwards to see if there is any run-out?
I'm used to stones where you have a really nice concentric and almost polished seat. I'd love to see some close-up pictures if any of you have them. I might be able to use my Kwik-Way Seat cutting setup with one of these Neway cutters to do the seat work (depending on the quality of the finish and concentricity). |
I bought this one from Amazon and found it worked just fine for my purposes, but I'm not a mechanic
![]() https://www.amazon.com/dp/B071WW28KN...fed_asin_title
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP ![]() Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand ![]() https://www.fordbarn.com/forum/album.php?albumid=580 |
Thanks. May I ask What pilot you used?
#12 | |
![]() Quote:
#13 |
Pic of my pilot,
it is made by W&B (warren and Brown ) has W&B V8 stamped pilot is .375 top diameter is 1.032 bottom dia 1.000 Lawrie |
#14 |
Thank you!
#15 | |
![]() Quote:
Stones B&S (Dale) are my preference even if they are slower. Lawrie I sure wish I could bring my Dad’s Wolf valve refacer over also as I believe it is as good as it gets. |
#16 |
Kiwi, I just slung out an old set of stones from my dads old US made set, let me know as they are still in the bin,
will get some pics Lawrie |
#17 |
This is what I use to check the seats
#18 | |
![]() Quote:
#19 |
This is my .375 B&D with extraction handle. I used this pilot without the handle on two valve jobs and it could be a pain wringing it back out. Last year when I bought my lathe in Seattle the guy had a bunch of 'outdated' automotve gear and asked if I wanted any of it. There was a Sioux seat grinder and a Sioux setup for counterboring the block for hard seats. In the seat grinder kit was this snap-lock handle for my B&D and of course it fit nothing in the Sioux kit. Just my lucky day.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#20 |
Totally off topic, but I have to ask: GB, why do you have a bottle of "instant rust"?
